| HELP!! Puffs of steam coming from engine Noticed that puffs of steam keep coming from my engine... not much and my car isnt overheating as the temp guage isnt moving and the fans arent coming on... i have noticed that the heating has been blowing cold, then goes bk warm... checked the water and thats all ok... any help would be really appricated as i dont want to be driving it still if i am going to cause more damage. thanks |
| Hi ya What's year and model is your car. It could be something as simple as dragons breath if it's a cooper S, that's where the water/rain goes in to the intercooler thought the scoop and engine boils it off so you get puffs of steam out of the scoop. It Can be quite alarming if you have never seen it before. I would say don't fully trust the temp gauge they are only there as a jesture there not that accurate As for the fans not cutting in there is a know problem with the stage 1 fan system so just be carefull. If you let use know what model we will be able to help you out abit more :-) |
| Hi its a mini one, 53 plate. My heating isnt working now.... sometimes comes on when doing high speed. And this morning there was a knocking noise coming from the engine for a few seconds, sounded abit like a cd when its skipping... and my engine is rattling... (god!!!) I took it to my garage to check the water (as the release cable to the bonnest has broken) he got in and everything seemed to be ok (water levels etc) im going to take it back in this weekend though and get him to have a proper look. Any help would be grately appriciated ![]() thanks |
| Hi ya Right mini one cool :-) umm as above bonnet release is a must ASAP If your heater is hot and cold you may have an air lock in the system mini's are known for there cooling problems caused buy airlocks it needs to be bled properly or the problem will never go away. If your fan have been coming on i would get your thermostate checked and also your water pump. If the water pump or thermostate are not working correctly water will not pass around the cooling system properly causing over heating and poor heating in the car http://realoem.com/bmw/showparts.do?...79&hg=41&fg=35 http://realoem.com/bmw/showparts.do?...99&hg=11&fg=35 |
| Thanks everyone. Had my mini in the garage over the weekend and the bonnet cable is fixed, and my cars been checked for leaks etc... the radiator has been bled and filled back etc. Was running ok until today, heatings stopped working again and it started to over heat... im taking it back to the garage this afternoon :-/ |
| Hi There around the £170 + vat mark from bmw parts dept, then you have fitting plus antifreeze ect For origanal part You can get pataren parts as low as £70 if no lower depending on if you A/C or not 1.4/ 1.6 2001- 2006 **NO AIR CON** So I would think if that £180 + vat will be for a pattern part a couple of hours work sounds close Why are thy changing the rad is it leaking Just be carefull that there not changing bits for the sake of it, anyway it harder from here as I we can see the physically see the car |
| Handy thread for bleeding the system if you need it http://www.mini2.com/forum/maintenan...screw-plz.html |
| Steam coming from front grill | eclipse | Maintenance & MINI Care | 11 | Dec 10th, 2008 10:38 AM |
| Engine Steam Clean | afiy2k | Maintenance & MINI Care | 4 | Jul 9th, 2008 09:20 PM |
| Steam train noise coming from front? lol | Mull3t | First Generation Faults & Fixes | 2 | Apr 20th, 2007 07:39 AM |
| Steam coming out | n00b | First Generation Faults & Fixes | 0 | Jul 14th, 2005 02:11 PM |
| Steam coming out of bonnet when raining or cold | rei00 | First Generation Faults & Fixes | 12 | Feb 13th, 2004 04:05 PM |
