reverse light - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 26th, 2012, 07:58 PM
Local Time: 01:08 PM
England
reverse light
Hi, first post so be gentle. Just got a 53 mini cooper s and have discovered reverse light dont work however when in gear i tapped the light and it came on. Took it out of reverse and put it back in and it wasnt working again! Now when i tap it the light just flickers. Could this still be a prob with switch as that looks like something i can do. Thanks john
Old Jan 27th, 2012, 10:12 AM
Online
Local Time: 02:08 PM
Could be the switch, or a loose connection.
Maybe even a dirty/corroded connection.
Try the simple faults first.
Old Jan 27th, 2012, 10:22 AM
England
a bloke at work seems to think it could be bulb or connection as it did work when you hit the lense, if it was switch he doubt it would work at all. my problem is how you remove the bulb and holder, all i can find on here is how to do it on other models, on the cooper s the exhaust is in the way! any ideas? thanks in advance
John
Reverse Light out MICKY MCS First Generation MINI Cooper S 0 Apr 11th, 2010 05:02 PM
No Reverse Light?!?! mini-coop First Generation Faults & Fixes 6 Feb 19th, 2008 10:14 AM
Reverse light and brake light Lorenzo7 General Discussion 0 Sep 30th, 2007 06:08 PM
reverse light SeXiTuPJoEy First Generation Faults & Fixes 0 Sep 19th, 2005 06:56 PM
White stobe light where reverse light used to be? CYNMINI First Generation MINI Exterior 8 Sep 28th, 2004 10:42 AM
