Mini Cooper 2002 - Reverse Light Problems - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 30th, 2012, 12:34 PM
Local Time: 02:09 PM
Hi,
Can someone help!!!
We have a 2002 Mini Cooper on which the reverse light has stopped working. I've ruled out the bulb and the fuse as these are both functional. This then leads me to the reverse light switch. Or are there any other potential causes of this?
If it is the reverse light switch I believe this is on the gearbox and accessible via the drivers side wheel arch (after removing the wheel) or through the engine bay after removing the air filter etc. Is this correct?
One more question, I've seen two possible reverse light switches for sale for this car, on an M12 and one an M14. Anyone have any idea of which one it maybe?
An info greaty received!
Many Thanks.
Luke
Old Jan 30th, 2012, 12:35 PM
P.S.
I've also had both front wheels off the car over this weekend and can't seem to see the reverse switch anywhere!
Does anyone have and pics of it or know of another way to get to it?
Old Jan 30th, 2012, 06:29 PM
mab01uk's Avatar
Enter your VIN/Chassis nunber in here to get correct part numbers:
RealOEM.com Online BMW Parts Catalog
Gearbox is on the passenger side (UK RHD). The Cooper reverse light switch is on top of the gearbox, Haynes manual says remove the plastic air filter box/intake hose assembly & maybe battery box to improve access, then unplug wiring connector and unscrew switch from gearbox casing. Some also have a sealing washer.
Tags: , , , , , , ,
Air Conditioning problems! Mini Cooper 2002 N Mini 61 First Generation Faults & Fixes 21 Feb 20th, 2012 08:47 PM
Mini Cooper 2002 - Reverse Light Problems lucass_247 First Generation MINI Cooper 2 Jan 30th, 2012 06:38 PM
Mini Cooper 2002 - Reverse Light Switch lucass_247 First Generation Faults & Fixes 2 Jan 24th, 2012 07:20 PM
2002 Cooper Fog light Problems Shockey First Generation Faults & Fixes 5 Jul 18th, 2011 06:48 PM
Mini Cooper 2002 - Clutch problems Sophia21 First Generation Faults & Fixes 5 Mar 23rd, 2011 06:27 PM
