Rattle noise , found it but what to do? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 1st, 2012, 08:33 AM
harvey94's Avatar
Local Time: 02:09 PM
Male
Hi,
I noticed a strange rattle noise from the engine the other day so i opened up the bonnet and had a look, please excuse my ignorance but i don't know the name of the part! Basically its coming from the part that the HT leads come from not plug into to! basically the small black box at top of engine is rattling , i can shake it and it moves, i have tried to tighten the bolts but they can't tighten anymore, thought about putting a couple of washers in to take up the slack but thought i would ask here first! i have taken the bolt off and its very long with a threaded end and a sort of rubber ring seal at the other.
Thanks guys!
Old Feb 1st, 2012, 10:30 AM
Hi
Sounds like the coil pack
It should have rubber bushes underneath it and on top of it to isolate it from the engine vibration.
Best thing to do is pop it off and check it only 4 bolts easy job
Old Feb 1st, 2012, 02:35 PM
harvey94's Avatar
Male
Quote: Originally Posted by marque (original)
Hi
Hi,
Thanks for the reply, there are indeed rubber bushes at the top but none at all at the bottom, I suppose this makes sense to the rattle now! Are these easy to get?
Thanks!
Suspension rattle, banging noise ? Socalcoopster First Generation Faults & Fixes 5 Feb 28th, 2012 10:57 PM
Rattle Noise After Engine Off neverending4181 Second Generation Faults & Fixes 0 Aug 27th, 2007 11:59 PM
Found cause of annoying rattle! caesar Second Generation Faults & Fixes 5 Jul 20th, 2007 05:39 PM
ABS and DSC noise/rattle leem First Generation Faults & Fixes 4 Jan 26th, 2005 12:22 PM
Rattle/ticking noise from the rear - found it mikeythemini First Generation Faults & Fixes 3 Sep 3rd, 2003 11:18 AM
