| Hello all, The motor mount (engine mount) on my 2006 MINI Cooper appears to be leaking. From what I have read this seems to be a DIY type fix. The only question I have is where can I get a replacement motor mount in the USA (a good reliable one)? Thank you for your help! (Picture of the leaking motor mount): |
| Hi Here s a few links that might help you out have a read. I am going for the vibra tech version next time, Also before you fit a new one make shore the rest of your engine mounts are in good condition, or you will find the new one will not last long Mini Cooper S R53 04 06 - Vibra-Technics Compliance Technology how to replace upper engine mount - North American Motoring Engine mount replacement. - North American Motoring |
| This is a place I buy parts from Way is a good guy to do biz with. By the way those things leaking is a very common problem. Way Motor Works 2004 MCS JCW, 15% pulley, Dinan CAI, MSD ignition & wires, Mynes V2 header, TSW rear control arms, H-sport front and rear sway bars, H-sport lowering springs, Powerflex bushings all around, modified Forge intercooler, M7 STB , ATI Damper |
| Hi ya Yer all three are a DIY job left hand gearbox mount and right hand engine mount and sabaliser mount underneath. I would only surgest changing them if you think they are worn out but I would advise having a good looking at them Anyway to make shore there ok though. Before doing you hyd right hand engine mount. Just make shore when you use a trolley jack under the engine to support it when you release the mounts do one side at a time use a piece of wood of something to spread the weight the sump can be damaged very easy, so don't use a jack directly on to it, I have abit of 1" thick ply wood. I don't think there are to much money for the others http://realoem.com/bmw/partgrp.do?mo...id=48020&hg=22 There are other options for the other two mounts like power flex bush kits or super flex kits it all depends on your budget. There are pro's and cons for both option and most o it's budget |
| Thank you everybody for your help. Yesterday I got the replacement part from the MINI dealer for $125. Today with my Dad's help we changed the passenger side Motor Mount. It was a fairly easy DIY job, and only took around 2 hours. The only downside is that we had to go to Pep Boys to get the E12 socket. |
| Leaking Engine Mount | BlueHuman | First Generation MINI One | 5 | Oct 1st, 2011 05:06 PM |
| Leaking Roof - Cant find the source | BlueSky | First Generation Faults & Fixes | 10 | Jun 10th, 2010 03:40 AM |
| Leaking Engine Mount | Purple Polly | First Generation Faults & Fixes | 3 | Jun 4th, 2009 08:55 AM |
| Leaking engine mount? | Sticks | First Generation Faults & Fixes | 8 | Oct 7th, 2007 07:03 PM |
