Smell from air vents? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 9th, 2012, 08:36 AM
harvey94's Avatar
Local Time: 02:10 PM
Male
Hey guys!
Bit of a strange one here so hope someone can help, my car has a smell that i can only describe as musty/mouldy , you only smell it when you turn the dial to blow from the front air vents and the heater is on hot, it only comes from the front 2 vents and not from the sides! Air filter has been changed and cabin pollen filter is also new. There was a period of time that the car was not used but it was garaged and not left on the street.
Any ideas? i know its hard as its a smell! i 100% don't think its antifreeze!
Old Feb 9th, 2012, 09:50 AM
minicore's Avatar
Super Moderator
United Kingdom Male View minicore's Chili Red & Body Color 2nd Gen MINI John Cooper Works Profile
Have you tried all the suggestions in this thread?
Old Feb 9th, 2012, 10:16 AM
harvey94's Avatar
Male
Thanks for this! i don't think its the same smell but the charcoal filter is worth a go!
Since i can only smell this with heat setting up is it safe to assume i would smell it if the dial was pointing to windscreen if it was still set to hot? what i mean is for example if it was a leak then i would smell it whatever setting the the blower was at and not just front air vent?
Strange Smell from Vents Mattstorm Second Generation Faults & Fixes 16 Nov 21st, 2011 12:08 PM
Air Con Smell Paul_Devon General Discussion 7 Jun 24th, 2008 11:24 AM
New Car Smell MiniSMan General Discussion 21 Jun 2nd, 2005 07:26 PM
Problems with the Foam under the Cowl Vents (twin vents near wiper arms) Ginger First Generation Faults & Fixes 12 Oct 29th, 2002 04:31 AM
