Car keeps unlocking itself - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 11th, 2012, 06:55 PM
Local Time: 01:10 PM
Hi, i've noticed recently that our Min is unlocking itself. Left it in a carpark today and locked the door then as I was walking away I heard it unlock. The re-locked it (with fob), lights flashed as norm and when I returned an hour later it was unlocked again. Happened after that too. Don't think the fob button is depressing in my pocket as it's quite a firmpress required anyway... Any ideas please?
Old Feb 11th, 2012, 08:14 PM
Canada Mini Driver
Canada
Something to check, search the site for "mini unlocking itself opening windows". I see threadid 166051, but I can't post URL's because of the site's anti spam feature
Could be battery (make sure your battery holds a good charge), or BC1 dampness. It does sound like a common problem, not one I've had with my R50 though.
Old Feb 11th, 2012, 09:31 PM
Local Time: 02:10 PM
Hi
If you have Another key try using that Incase the fob is bad
The body control unit is another good place to start it located in the drivers foot well right hand side behind the trim.
From what I have been told the early minis never had a plastic guard to help stop the water getting in the bc unit and the plugs it's well worth checking it out.
The bc is a culprit for a lot of faults
Old Feb 12th, 2012, 08:57 AM
mab01uk's Avatar
As marque says could be a BC1 problem especially if its an early Mini, more details in link below:
The BC1 (Body Control Unit) - Forums
boot not unlocking jd78 First Generation Faults & Fixes 1 Mar 20th, 2011 07:30 PM
car keeps unlocking itself...?? bruce-lee First Generation Faults & Fixes 1 Dec 20th, 2010 06:30 PM
Lights on when unlocking SClubber MINI Clubman 11 Nov 6th, 2008 03:11 PM
Doors unlocking m19dut First Generation Faults & Fixes 2 Oct 28th, 2005 12:27 PM
