| Help, 2003 Cooper gearbox (I've searched) Hi guys. Just a quick one, my girlfriends 2003 Mini Cooper has a problem. Now, its got 70k on the clock and having read up it appears that the 'Midland gearbox' might be on its way out. Basically it started months ago A slight whining noise until the clutch pedal was pressed, then silent. Anyway, its got worse to the point where it now clunks and clonks all the time (now very loud) Ive jacked the front end up and when i spin the front passenger wheel its cliking and clonking (sorry about my sound descriptions )So having just replaced my mates VW gearbox and clutch im thinking I might just get a reconditioned box and swap it. Can anyone let me know if this sounds like the box. Im worried that the clutch and flywheel might have some part to play... BUT there is no slipping or play in the pedal etc etc Many thnaks guys, I really appreciate any feedback before i proceed Thanks Ian |
| John Tee at 'Minigearboxes' (link below) is a Mini2 member on here and should be able to advise and help you if you give him a call, he may also give you a good price on a recon gearbox if it is required: mini gearbox, gear fix - Mini recon gearboxes | BMW MINI cheap gearboxes Early MINI Rover Midland Gearbox - Forums |
| Cooper 2003 gearbox removal | Stigsdump | Maintenance & MINI Care | 2 | Jan 7th, 2012 09:36 AM |
| Cooper 2003 Brake sensor issue (I have searched) | Coooop | First Generation Faults & Fixes | 9 | Mar 24th, 2011 11:56 AM |
| Gearbox Problem With Mini Cooper 2003 | daz1761 | First Generation Faults & Fixes | 0 | Mar 17th, 2011 01:43 PM |
| will a 2003 cooper s gearbox fit a 2002 mini cooper ? | samg6620 | First Generation Faults & Fixes | 5 | Aug 6th, 2010 03:50 PM |
| Cooper S New gearbox 2003 or 2004 | Pglenning | First Generation MINI Cooper S | 3 | Oct 25th, 2006 10:27 PM |
