2002 cooper s auto climate control heaters\blower dead - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 6th, 2012, 07:38 AM
Local Time: 01:09 AM
hi, woke this frosty morning got in my 2002 cooper s went to use blowers/heaters,, nothing , the auto climate control gauge and all the lights on windscreen heater buttons etc all work and to look at seems fine,,but just no heat or blow totally dead,any help on a fix? ,steve
Old Mar 6th, 2012, 07:47 AM
mab01uk's Avatar
Online
Couple of links below which might help:
http://www.mini2.com/forum/first-gen...ack-found.html
http://www.mini2.com/forum/first-gen...t-working.html
Old Mar 6th, 2012, 09:49 AM
cokey's Avatar
Local Time: 12:09 AM
United Kingdom View cokey's Classified Ads
Yeah, the first link Mab01uk posted was my thread. Basically I had exactly the same issue as you. I presumed the resistor-pack needed replacing but soon found that the blower in my MCS03 dosen't have this resistor. Mini were completely ignorant to the fact that early MCS had a different model blower that didn't have this resistor pack. Mine was built in Germany - not sure if that makes a difference.
First thing to do is look in the drivers footwell to see if your blower has or doesn't have this resistor pack. If it does then it might just be a simple case of getting a replacement and swapping them out.
My problem seemed to be the fan motor was sticking. I found that when the fan wasn't working, if I switched the mode on the climate control while driving, it would get the fan working again. Can't remember which mode used to do it (auto, windscreen etc) but I'm sure it was due to the way the actuators changed the air flow. The change in air flow would then actually move the fan blades round and that would get the motor going again.
When I took it into Mini for their bulls**t diagnostic (see Mab01uks first link) the technician sprayed some WD40 to the blower motor via the engine bay (there's a vent that gives a tiny bit of access to do it). The blower fan has worked ever since that day - nearly a year now, but i'm not crediting that one to Mini as they were useless!
Old Mar 6th, 2012, 04:25 PM
what do i look for in footwell? nothing seems prominent, the auto climate buttons seem to sound like a cd trying to search for a track before erroring, weird.
Old Mar 7th, 2012, 12:40 PM
cokey's Avatar
RealOEM.com BMW R53 Cooper S Resistor/temperature sensor
That diagram is the heater/blower unit - No.2 is the resistor pack. Stick your head in the drivers footwell (presuming it's righthand drive) and look upwards to the left of the pedals. You'll need a torch and maybe a mirror. You should be able to see the resistor pack. If there is just a blank space where it should be then you've got the same as me - the version with no resistor-pack that Mini seem to know nothing about! See my photo here: http://www.mini2.com/forum/attachmen...2&d=1300882983
The noise that you here when you press the 'auto' button is most probably the actuators moving. The actuators are little motors that open and close certain airways within the dashboard, leading to the different vents.
2002 Mini Cooper Auto Trans Dead? W0ot! 02minivegas General Discussion 3 Oct 24th, 2011 05:04 AM
To add an auto climate control to a non-auto climate mini pcho First Generation Interior & Ice 5 May 20th, 2004 10:40 PM
Auto AC climate control DarkMiniCooperS First Generation Interior & Ice 11 May 12th, 2004 09:27 PM
Auto Climate Control ruthie First Generation Interior & Ice 1 Apr 3rd, 2003 06:09 AM
Climate control/Blower will not work S-Cooper First Generation Faults & Fixes 6 Nov 13th, 2002 11:15 PM
