Failed MOT - emissions and headlight beam - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 12th, 2012, 04:30 PM
Local Time: 01:05 AM
Bloomin' emissions failed- first and second tests lambda reading was 1.041 (think max permitted was 1.03). Would it make a difference if the car had a good run before the test - MOT is only 5 mins from home and went there from cold.. If not, which lambda would need replacing?
Also failed on o/s headlight beam angle being 'clearly wrong'. It's not the height and have checked that the bulb is seated correctly. When lights are on it's very different against the gararge wall to the n/s lamp..
MOT failed on emissions and engine light now on cokey First Generation Faults & Fixes 7 Mar 6th, 2012 04:22 PM
MOT failed on emissions 52 plate mini cooper Tatie-Tot First Generation Faults & Fixes 4 Oct 29th, 2011 01:03 AM
Failed MOT and emissions light Jack678 First Generation Faults & Fixes 0 Apr 12th, 2010 02:56 PM
Failed MOT on Emissions? Reesie Maintenance & MINI Care 6 Sep 4th, 2008 07:44 AM
Failed MOT on Emissions: update - still need help! HObzy First Generation Faults & Fixes 31 Dec 14th, 2007 05:28 PM
