Indicator Problem - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 22nd, 2012, 08:41 AM
Local Time: 03:49 PM
Indicator Problem
Hello,
Ive recently pruchased an 06 Mini Cooper Park Lane and I am having some problems with it, mainly:
Indicators dont always signal inside car (fine on outside)
Dash board dims
Rear Windscreen heater doesnt always work
Break lights stay on when parking
Main Beam does not signal when flash lights on dash board (fine on outside)
Central Locking from key does not work
This all happens at the same time and is not constant. BMW have replaced with main GEM (??) module computer but this has not worked and nothing shows on their diagnostics, any ideas????
Old Apr 22nd, 2012, 08:49 AM
mab01uk's Avatar
Possible faulty cell breaking down in the battery?...........if it is the original BMW battery it is now 7 years old and could be intermittently failing internally, low battery power on Mini's causes all sorts of strange electrical glitches and it is not always obvious that the battery is the cause.
Also the various wiring earth points around the car should be checked carefully for good connections to the metal body especially where exposed to outside corrosion in engine compartment, etc, also check for water/moisture ingress into any control modules, connectors.
I assume the main GEM (??) module computer means the BC1 which you say has been replaced, more info on that here:
The BC1 (Body Control Unit) - Forums
odd indicator problem ch0ne7 First Generation Faults & Fixes 5 Sep 21st, 2011 08:30 PM
Indicator problem Kitis_1989 Second Generation Faults & Fixes 1 Jul 21st, 2009 08:59 AM
indicator 3 flash problem rosemj2 Second Generation Faults & Fixes 6 Apr 23rd, 2008 11:57 AM
Run flat indicator problem blackminione Wheels, Tyres & Brakes 3 Apr 2nd, 2008 04:20 PM
Problem with outside temperature indicator All Black Mini First Generation MINI Tuning 3 Dec 4th, 2005 02:43 AM
