Power Loss between 3000 and 4000 rpm please help - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 6th, 2012, 10:54 AM
Local Time: 05:29 AM
Greece Male
I have this problem in my r53 JCW 2004 model:
with 3rd and 4th gear and maximum acceleration, full throttle have power loss between 3000 and 4000 rpm like 2 or 3 small cut offs
if anyone can help me I would appreciate
Old May 6th, 2012, 03:08 PM
Acallahan's Avatar
MINI fanatic
Local Time: 11:29 PM
United States Male View Acallahan's Classified Ads
check fuel injectors and also what quality of fuel are you running ? I would try a couple bottles of fuel system / injector cleaner in your tank and see if there is any improvement. I also would get the codes checked and see if you are throwing any codes.
2004 MCS JCW, 15% pulley, Dinan CAI, MSD ignition & wires, Mynes V2 header, TSW rear control arms, H-sport front and rear sway bars, H-sport lowering springs, Powerflex bushings all around, modified Forge intercooler, M7 STB , ATI Damper
Old May 6th, 2012, 09:07 PM
Greece Male
The problem start after the inspection 2 service at 82000 km
they put wrong plugs BKR6EQUP NGKs fitted rather than the specified BKR7EQUP and start the cut offs
I go the next day and they put the correct plugs but the problem don't go.
the dealer check the fuel injectors and they are OK
I put yesterday a bottle of cleaner and I wait. make 60 km and see some improvement but the problem is there
Old May 27th, 2012, 09:15 AM
Greece Male
I check the coil for corrosion I clean them and put dielectric spray
The car is better
No cut offs in 3d and some times 1 cut off in 4th speed
Old Jun 7th, 2012, 07:45 PM
Greece Male
I check the coil and the sparkplugs again I clean them with metal brush and put dielectric spray
THE PROBLEM SOLVED
Thank you all
problem Power Loss between 3000 and 4000 rpm APOBEK First Generation Works 0 May 3rd, 2012 08:31 PM
Loss of power Jwmmini First Generation Faults & Fixes 1 Jun 16th, 2010 01:11 PM
Power Loss!!!! Help Please!!!! holkin First Generation Faults & Fixes 14 Oct 15th, 2008 07:58 PM
Loss of power aweezelhed First Generation Faults & Fixes 18 Jun 1st, 2006 01:01 PM
Loss of Power Abbo First Generation Faults & Fixes 4 Jul 18th, 2003 01:23 AM
