Mini overheating/fan stays on?? how to cure Hello all, My girlfriends 2001 mini one has developed a strange range of symptoms and I am at a loss as to the cause. The symptoms are:
1.engine fan comes on full blast after approx 15 mins and stays on when engine turned off for about 5 mins
2.interior heaters blow cold even when on full temp (no damp patch near heater matrix)
3.exterior temp display(on pod when rev counter) displays 50 degrees C constantly (currently 15 degrees not 50)
4.engine temp reading halfway (correct??) then shoots up high when car parked up and turned off, also when car ticking over and stationary.
5. car was losing coolant but a leaking upper radiator hose has been repaired and so far no coolant loss after 2 days.
6. before the hose was repaired the car lost power, suggesting it was actually overheating, not just a false temp reading causing the fan to kick in.
Does anyone have any clue where the problem could lie?
also, are the engine and external temp readings related? possibly faulty thermostat causing false readings and fan to kick in needlessly??
There seems to be so many potential causes that I have no idea where to look first. If anyone has had similar problems or has got a clue where to start looking I would really appreciate the help.
Thanks |
