Airbag Light and B800 reset tool showing code 1 and 15 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 7th, 2012, 05:04 PM
Skitos's Avatar
Local Time: 05:22 AM
United-Kingdom Airbag Light and B800 reset tool showing code 1 and 15
Hi,
I need some help please, I have recently brought a second hand R50 mini Cooper and the air bag light is on.
following this forum I purchased a B800.
I have read the instructions, plugged it in, checked the FA code Table which was 10, then checked the codes within the table, this is what i found:
Table 10
01 Firing Circuit, drivers Airbag, stage 1
03 Firing Circuit, belt tensioner, passenger side
05 Firing Circuit, Side Airbag, front left
15 Firing Circuit, drivers Airbag, stage 2
using the CA option did reset 03 and 05 codes.
But I still have
However could this be passenger, reason I ask is that when I got the car I was told that the light came on only after it was broken into and the airbag passenger side cover was forced off thinking it was a glove box, as the B800 is made in china could it be that the manual is for a LH drive car?
Could I fool it by fitting 4 ohms resistors to work out which one it is, would need to know which pins to connect.
Any help would be grateful.
Regards new mini owner Richard
Old Sep 8th, 2012, 01:43 PM
Skitos's Avatar
Quick update, with thanks to mab01uk,
He thinks that the B800 would work the same whether LH or RH drive car as it is only looking for the components...does not really matter where they are located?
So i have today taken off the drivers air bag, reconnected the battery and then turned the car on, re checked logs no new codes. so 1 and 15 must be for drivers air bag.
I then brought some 4 ohm's resistors and connected these into the connectors which would go to the air bag and tried again to clear fault codes, still wont clear so now thinking it might be the clock ring.
Any thoughts?
Old Sep 14th, 2012, 06:44 PM
Skitos's Avatar
Thumbs up Fixed Air Bag Light
Quick updates, been busy on eBay managed to get a second hand multi-function steering wheel with air bag for £16 only wanted the airbag, (but had to do a 80 mile round trip to get it).
Then brought a slip ring off eBay for £17.
Went to fit the air bag and slip ring today and when I moved the slip ring forward found the plug had come off. Refitted plug put it all back together. The loom was tight so re worked it.
Interesting I found an old rusty T25 socket bit by the slip ring so some one has been in this location before.
Reset system with B800 now all ok
FAULT LIGHT HAS FINALLY GONE
If anyone lives near Dartford Kent you are welcome to use my B800.
So total costs:
B800 £21 off eBay from China, delivered in a week
Complete Steering wheel with Air bag £16
Diesel (in my cay) £15
Slip ring £17
Total £69 my local mini specialist wanted £50 just to look at the codes. Plus might sell the air bag and steering wheel so might break even.
Old Sep 15th, 2012, 07:52 AM
hanoi's Avatar
Local Time: 06:22 AM
View hanoi's Pure Silver & Body Color 1st Gen MINI One Profile
Good work there for £69.
Essential to repair as it is a safety feature which could save a life and its become part of the MOT. Honest John in the Telegraph recommends a company which does this sort of stuff cheaper than the dealer.
air bag man
