05 Cooper S works - metalic rattle from exhaust - bushes? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 18th, 2012, 04:46 PM
JamesTeehan
Local Time: 05:41 AM
Hi Guys,
I've noticed a tinny rattle coming from the back box area of the exhaust, as if, whilst vibrating, its hitting something.
I've sort of figured that there must be too much movement, and concluded that changing the bushes might cure it. Problem is, I cannot find a set of exhaust bushes anywhere on the internet. Does such a thing exist? and also are they specific to the Works tuning kit, or will they be the same as the standard Cooper S bushes.
I'll be honest, I haven't pin-pointed the noise yet, so it might not be the answer, but for what they cost, I figure it'll be worth swapping them.
Ta
James
Old Sep 18th, 2012, 04:59 PM
Could be a loose baffle inside the box too?
Old Sep 18th, 2012, 05:03 PM
Have a look on sites such as realoem.com or bmwmini parts for the exhaust suspension stuff
Old Sep 21st, 2012, 04:01 PM
JamesTeehan
I agree... I reckon this is most likely now to be honest, I really can't see that its actually hitting anything. Can't say I'll be bothering to change that, £500 plus fitting is far to steep... might have to just turn the radio up!
Will have a look at those sites... cheers!!!
Old Sep 21st, 2012, 04:26 PM
Check the clearence between the battery sheild and the tail pipes, if the exhaust drops slightly or the sheild gets bent up they can knock together, it's quite flexible just pulling down on it slightly will increase the clearence.
Old Sep 22nd, 2012, 06:34 AM
MCS-W11NJP
Local Time: 04:41 AM
Drive it like you stole it for 10miles that will sort any loose baffle
Old Sep 25th, 2012, 03:05 PM
JamesTeehan
Eh? Really? how does that work?
I drive like an old dear most of the time to keep the MPG up.
Old Sep 25th, 2012, 03:33 PM
Blow it out
Old Sep 25th, 2012, 04:52 PM
Quote: Originally Posted by JamesTeehan (original)
Eh?
Most old dears drive around in first gear all the time though.
