| Probably the radiator, they can leak from the lower front corners after a few years especially on earlier Mini's. Rads vary from around £100-£200+ depending on whether aftermarket or a genuine BMW part..... plus labour, vat, etc, unless you are into diy mechanics.
Or if could be a leaking hose which would work out cheaper........don't run the car with low coolant or you could blow the head gasket which is very expensive!! |
