My 2002 mini cooper has suddenly decided to develop about half a dozen expensive faults. The one I am tackling at moment is intermittent fault of drivers window motor. (can be temp cured by smashing door above speaker!) Been diagnosed by local mechanic as needing a new motor and regulator. Howver the parts are over £250 from BMW. I have found some aftermarket parts for a fraction of this the mechanic said my window has the automatic drop function on this and therefore that swhy part is dearer??!! I thought all mini coopers would have had an auto window? Can anyone please advise?
As far as I can see all the connectors to the motor are a 2 pin assembly? Are the connections always the same.
Anyway any help most gratefully received, anyone out there with non auto drivers door window?
Anyone got any advice to getting this done at a better cost than best part of £300!!
Any successful help will result in a decent charity donation of your choice!
