Fuses fault - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 5th, 2013, 11:43 AM
Local Time: 10:36 PM
England Male
Fuses fault
Hi all I am hoping someone can give me a clue how to sort out a few problems I am having with my 2002 cooper s? I went though a big puddle in my mini and some water came in my car, have Dryied out the car and all is working well, but now the electric sun roof, inside instrument cluster dash lights, front window wiper wash pump and the built in sat nav is now not working, I have cleaned and Dryied everything out and all so put the BCU in the airing cupboard for a week just in case that was wet, I have checked all the fuses and they are all fine too. So the next thing I did was to remove passenger compartment fuesbox and I remove fueses F8,F5,F15,F23 & F30 (one at a time) and with my electric tester I tested each one, and I found that there is no power going to each one of these fueses?? does anyone know why this is and what the fix can be, could it be a relay if so what one and were is the location?
If anyone could give me some advice I would be greatfull as I have come to a dead end and don't really want to take it to a garage and have a big bill if needed.
Old Jan 5th, 2013, 12:44 PM
England Male
Further investigation I now have power to all the fuses but not fuse F5.....?
Old Jan 5th, 2013, 01:22 PM
Local Time: 11:36 PM
I only have a manual for the Gen 2 MINIs so cant reference what F5 is for.
But on the later cars there are fuses that supply the fuses in the footwell so to speak, main ones, under the bonnet?? have you check there too??
Old Jan 5th, 2013, 02:22 PM
England Male
The F5 fuse is for the control module for the instrument cluster/diode, I have check all other fuses and they all seem to be ok?
Old Jan 5th, 2013, 06:16 PM
mab01uk's Avatar
Online
BMW Planet has lots of useful electrical information which may help. This is for the BC1 for example:
http://www.bmw-planet.com/lib/mini/B...L%20MODULE.pdf
Download of pdfs:
LIB > Mini technical documents | BMW-PLANET.COM - BMW DIY, Knowledge base, Library, Technical resources, Galleries
Old Jan 5th, 2013, 08:13 PM
England Male
Thanks for the info, I have checked out the BCU and that's all fine, just need help on why there is no power the to the F5 fuse? A
