Windscreen washers both not working ;/ - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 7th, 2013, 11:52 AM
Local Time: 12:16 PM
Hi guys,
2003 JCW.
Both my windscreen washers (front & rear) aren't working and I'm pretty sure they both went out at the same time.
Details: I can hear the motor buzz. Both reservoirs are full of water and don't seem to be leaking (filled them up several days ago and the level is the same today). I have pinned the jets and still nothing comes out.
I read on here a thread in which a guy dismantled his rear wiper and found it corroded and upon cleaning it up and oiling his washer worked again - i.e. it wasn't blocked rubber tubing. But I'm guessing the answer is in the detail - as both went out at once it IS blocked tubing? Where would that most likely be? Like where in the tubing? Can I fix this myself or is it a dealership visit?
I gather this is urgent, if not illegal, as if my windscreen gets dirtied and the wipers don't solve I could be in lack of vision doggy do do ;b Thnx!
Old Jan 7th, 2013, 12:47 PM
mab01uk's Avatar
Online
Local Time: 01:16 PM
This link should help:
Windscreen Washer Motor Troubleshooting - Forums
Old Feb 11th, 2013, 12:58 PM
We had a similar problem with the front washers losing pressure on a MCS cabrio.
I took the washer bottle out (take off the wheel, then carefully remove the arch lining).
Discovered there was a thick black rubbery deposit on the motor inside the tank.
Disconnected the motor from the tank and flushed it through and all is good.
I was advised that this is a common issue with BMWs and they "recommend" only using their own washer detergent.
A low skill but messy job. Be careful if you disconnect the motor power and flush the tank from the top you can easily spout water into the electrical plug!
Old Feb 11th, 2013, 02:07 PM
Online
They normally fur up when only water is used without any additive
Old Feb 15th, 2013, 06:03 PM
Not on our car. I don't know what caused it but the tank always had plenty of wash. Often more or less neat. The plug was like a blob of soft rubber. I guess it could have been the previous owner but I'll never know.
