I've been browsing these forums for a while but unfortunately this is the first time I've needed to post. basically I curbed my first gen mini one a while ago (weeks) and I didn't notice anything wrong. few days later I got stopped by a guy at roundabout who said my wheel was about to fall off so checked but couldn't see anything. few days after that got stopped again and police took me home. They couldn't see anything when car was stationary but again said it looked wobbly and could fall off.
got home and jacked it up and tightened wheel nuts but didn't see if it made situation better because someone said they saw a crack behind the wheel so I didn't want to drive her. I've looked a few times now and still can't see anything apart from dent in hub cap which I don't care about if not dangerous.
Anyway, does anyone know what might have happened (best and worse case scenario) and how much it's likely to set me back?! Just so I know what's going on at the garage...
Yep, I tried spinning the wheel when it was up and it didn't budge at all, which is why I thought something more than just a loose wheel was wrong with it.
I was probably going about 30-35 when I skidded, but I didn't hit the curb until after I'd slipped and slammed on the brakes, so it would have been less at the point of impact.
I'm going to get it sorted (I'm not driving it) but I just want to get a rough idea so that I know I'm not getting ripped off/sold useless parts. I can try and get a picture of how the everything looks if that would help?
jack the car up and check for play in the wheel bearing, grab the wheel at 12 and 6 oclock and wiggle it! If there is *any* play your wheel bearing has had it, if no play move on to 3 and 9 oclock and try again.
Going at that speed i would be amazed if you hadn't bent a steering control arm or perhaps more! It would be worth getting under the car with the whole front jacked up and try to compare your curbed side suspension to the known good side.
edit -
video included -
I can't link videos until i have 15 posts, but if you go to youtube and paste this in you should get it -
watch?feature=fvwp&v=JSsC-lWB1lg&NR=1
i really wouldn't be surprised if yours was as bad as that (if it is a bearing!)
Are you getting any odd steering feel? Any new noises? If this checks out you could just have a bent wheel, but for people to stop you it would have be massively severe which makes me think you would be able to see it!
It's not an alloy wheel. I'm not sure about the crack behind the wheel, it was just something my landlady said and pointed to but every time I look I can't see it?
I'm not going to drive her until I take it to the garage, but I just wanted an idea of what it could be (and the cost) before I get ripped off because I'm a girl going on my own!
I also haven't noticed much wrong with the steering but I've only done one long journey in it (and that was after the curb!), where it didn't feel completely stable when going at speed (it wasn't drifting but I didn't feel comfortable going over about 55/60)
There is no wiggle/movement on the wheel when jacked up at all!
Do we know how much these things are likely to cost me to get repaired (in Oxford, UK)? I just don't want to take it to the garage if it's going to be more than £3-400 because I can't afford to pay for that at the moment, I'd rather just leave it at home and walk everywhere for a while...
If you don't want to go to a garage, do you have AA or RAC type breakdown cover? If so drive to a convenient place (they won't normally come to your home address unless you have extra homestart cover) and then call them out saying your wheel is wobbling and you are worried and want it checked out before driving home. The AA man will come out diagnose the fault/repair as required and either let you continue to drive home or recover you and car to your home address/or garage of choice.
If the wheel is wobbling visibly it must be terrible to drive, do you not feel any vibration at all? Also if the wheel has had an impact that hard, it might also have bent or damaged a suspension or steering part or the very least knocked the tracking all out of alignment?
It needs a good check over not just the wheel part.
Yeah, I have home start as well. I just was a little bit nervous about getting it recovered to my garage and then it costing too much to repair immediately and then having to leave it 5 miles away for a week or two, or not being able to get it back and not being able to get another recovery to the garage!
the only trouble with that is that I've not had it (or my license) very long so I'm not an expert in how it should feel, as I did the knock quite soon, plus the day after I got it the steering went so it's never been perfect.
It does vibrate at higher speeds but where I live is mostly 30-40 and I can't feel anything in particular then. I also think it may have gotten worse by the time someone stopped me...
if your nervous of the garage all i can really suggest is some really good quality photos (of the wheel/ suspension - with the steering on full lock), but without seeing it - it's hard to diagnose over the 'net!
I know, I know! I just wanted some ideas of what it could be, so I'll ask the RAC guy when he comes. Everyone's made me feel a lot better because I was worried it'd be written off or the part would be more than the car is worth or something horrendous...
How did you hit the curb? Was it just a rub, or did you hit the curb face on? I just had a really daft though, your wheel trim isn't loose is it? I've seen those make it look like the wheel was about to fall off, but infact it just needs pushing back into place / renewing.
