Headlight help pls - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 20th, 2013, 04:53 PM
Local Time: 06:59 PM
Headlight help pls
Hi guys
I have a 2004 cooper s and what to confirm these models all have auto sensored head lights first?
Secondly if so I presume I have to leave the stalk on the on position and the car sensor will turn then on and off when the light is correct etc. at the moment I'm having to do it manually as they are not coming on or going off automatically although the auto wipers do work. Any ideas pls how or if I can fix this/ turn them on?
Old Jan 20th, 2013, 09:33 PM
Online
Auto headlights was, I believe, an 'option'.
If you have them, you'll have an 'A' on the stalk below the off position.
There's also another factory option which mine also has. That if you leave the stalk in the 'headlights on' position, then remove the key from the ignition, the headlights go off but sidelights stay on.
Old Jan 21st, 2013, 07:58 AM
Thanks, the car does have the vis pack in it so presumed that included auto lights but must be wrong.
Cheers for the help anyways
