| We're in the middle of winter in upstate New York, temps last night fell to silly numbers below freezing but we have been experiencing a frozen gearbox. Haven't found anyone with a similar posting. Taking 15 minutes to warm up, last night was tough coz someone left it in gear! Let me know if I am alone! |
| That's the view of my BMW service department....two and a half hours away from home. "We'll need the car for a few days to try and replicate the problem". What's the matter? Don't you believe me? Look, I know a frozen gear stick when I see, feel, have one. They'll get the car when I know they know what the problem is. So that's where my Mini2 friends come in. HELP!!!! Anyone aware or suffered a similar problem? I happened to visit the Keeler service department on a day when the helpline was closed...hmmm...I called 2 weeks ago and told you what the problem was.... Drop me a line if you're aware of anything I can use. Thank you in anticipation. |
| Can you move the shift lever with the engine off? If so, then the gearbox is probably okay. If the stick won't move at all with the engine off, then there is either a fault in the gearbox or something (ice, perhaps) is jamming the shift mechanism. If it won't shift only when the engine is running, then suspect the clutch is not releasing. It could be a bad throwout bearing. |
| The service manager at my dealership has reported that the frozen gearbox is a first for Mini, least it hasn't made any records at HQ. They plan to drop the transmission (oh great) to take a closer look unless otherwise advised by Mini in the mean time. Here's hoping they don't have any problems or reduce my Cooper S to anything less than the pocket rocket I remember it as. Woe is me, it's like having a root canal... |
| It doesn't go into gear when engine is off Mr Bill Thanks for your suggestion, tried it last night and it doesn't go into gear. Any ideas will be passed on to my new friends in the service department. |
| Frozen Gearbox This AM the temp was 16 degrees F when I left the fire station to start the S. The motor fires just fine, thank you soft ware change, but the gear selector would not move from neutral. I waited about 10 minutes at idle, the thermostat was at the 1st mark, when things came together and into gear we went. 2 calls to MINISTL for advise and one to MINI Minneapolis and I thought I would pose the question to this forum. The dealers feel the lube is the cause and that it may be normal for a 10-20 minute idle to warm the lube enough to allow shifting. I am the first to ask this question of both dealers. The regional rep is to be at MINISTL on 12-5 and I hope to hear his advise. Anyone else had this problem yet? I hate to think what will happen when we hit 10 below this winter! Mike Semper Fi Electric Blue/White roof Sport package stripes,lights, born 29 Mar 02 delivered 17 May 02, 1 pm CST in STL USA, 1st S in Iowa |
| The other day when the temps were -18C here (-2F) my 5-speed Cooper gearbox was sluggish at first but usable and was fine after a little warmup. Harry MINI Cooper Cabrio: now the car with go cart handling really feels like an open go cart! "... the only man that can come home at 3 am in the morning without getting into trouble with his spouse is the owner of a British sports car!" -- Phil Bailey |
| At 15F yesterday here north of Boston, I had no problem shifting my MC ... cannot believe that what you describe is correct; these cars are arctic tested! Ian C. Gloucester, MA |
| Fine at 12 deg. F yesterday... Here in Rochester, NY. Started it up and drove it away. I've got to believe the problem is isolated. Ask the dealer if he is telling you that *all* their MINIs do not shift at low temps. Sounds like your dealer is trying to blow you off with a BS story. Chili Red / Black Roof Cooper "S", delivered Aug 5, 2002. If you have read this far you are obsessed - Make a donation to MINI2 and become a sponsor! Enjoy every sandwich. - Warren Zevon |
| 15F when I pulled out this morning - no problems. Your manual trans fluid should be synthetic and thereby only mildly affected by the temps. Perhaps your fluid is too low or - not there? Jason Jason Livingood | personal web site 2002 DS/W MINI Cooper S Thank you for signing my rear fog light petition. Now we have rear fogs! :-) |
| I also experienced this. The temperature the past few days has been around 10 F and the last time my car was out for a whole day the gearbox was frozen. I usually leave the car in first gear so I had to force it back to neutral position. I never experienced a gearbox THAT frozen. I am surprised that most of you did not experienced this. I will have to ask my dealer about this. |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-faults-fixes/19698-frozen-gearbox.html | ||||
| Hello! New to M|U - Page 3 - motoring|underground | This thread | Refback | Jan 2nd, 2009 12:03 AM | |
| Frozen Gearbox | Zipperblues | First Generation Faults & Fixes | 1 | Feb 16th, 2007 11:10 AM |
| Frozen gearbox ? | wwwebber | First Generation MINI Cooper S | 12 | Feb 11th, 2007 11:03 PM |
| Mod Frozen Gearbox | KARENM | First Generation MINI One D | 7 | Mar 31st, 2006 06:13 AM |
| Frozen Gearbox | graniteguru | First Generation Faults & Fixes | 2 | Jan 21st, 2003 01:31 AM |
| Frozen gearbox??? | bigbaddaboom | First Generation Faults & Fixes | 2 | Jan 14th, 2003 04:28 PM |
