Hi
This morning my 53
MC failed to start. The engine does not turn over and the eng & oil pressure lights go off when key is in start position, tried a jump pack with same result. One thing I did notice was that the power steering pump starts to run when key ii turned to start position and continues to run until the ingnition is turned off, does not run with key removed as is the normal problem with starter motor running battery flat.
Is this the power steering fan causing the problem by drawing too much power and not leaving enough for the starter.
any help appriciated
Pat
