Is Temperature Gauge OK? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 12th, 2002, 05:15 PM
crunchie's Avatar
Local Time: 02:11 PM
Advice Please.
Before I ring my dealer
I have noticed on start-up and for about half a mile the temperature gauge rises, to half way between normal and hot, then settles at the normal.
(Weather has been near freezing lately) could be something to do with the thermostat opening.
Has anybody else experienced this?
Thanks in advance for any replies.
Crunchie
Old Dec 12th, 2002, 06:50 PM
L8 Apex
Guest
Posts: n/a
I think I would get this checked out. Usually, at least as far as I know, the valve from the engine to the radiator is opened by the same sensor that gives you the engine temp on the dash. Your mini might actually be overheating, and then cooling down to normal. But then again, it might just be the gauge.
I would get it checked out, better safe than sorry.
-Andrew
Old Dec 12th, 2002, 09:33 PM
cosworth's Avatar
Local Time: 08:11 AM
Yeah, I think Apex may be right. Mine comes up slow and steady to the halfway mark, and stays there. Possibly a sticking thermostat. Take her in for a check.
2002 MCS, DS/B/BBS, Sport, Prem, Cloth, 17's
1969 Morris Cooper MK2, Tartan Red/Black, 998cc, Twin HS2's
Old Dec 13th, 2002, 09:12 AM
Local Time: 09:11 AM
United States View sjbartnik's Electric Blue & White 1st Gen MINI Cooper S Profile
The coolant thermostat (as in pretty much all cars) is a completely mechanical device and is not controlled by any type of sensor. It is a thermostatic device that is totally controlled by the temperature of the coolant.
That said, you should certainly get it checked out. Perhaps the thermostat is sticking and is not opening on time, or perhaps you just have a faulty gauge or sensor.
Sean Bartnik
2003 MINI Cooper S
Old Dec 13th, 2002, 05:31 PM
Local Time: 01:11 PM
Info only....
The thermostat is located in the cylinder head and is retained in a plastic housing located at right side
of the engine (viewed from the front of the car).
The thermostat begins to open at 89-92 °C and is
fully open at 103 °C. The thermostat housing also incorporates the cooling system pressure cap on a
MINI ONE and MINI COOPER.
The engine temp guage is also damped..The needle will remain in the straight up(12o'clock position)when the cooling systems is between 76 °C and 112 °C.
So any temp change above 112 °C and the guage goes into the red, and any temp below 76 °C and it shows cold..
Hope this info helps
Old Dec 13th, 2002, 06:10 PM
L8 Apex
Guest
Posts: n/a
sjbartnik The coolant thermostat (as in pretty much all cars) is a completely mechanical device and is not controlled by any type of sensor. It is a thermostatic device that is totally controlled by the temperature of the coolant.
Yeah, thats what I meant..You just said it more accurately.
-Andrew
Old Dec 14th, 2002, 12:15 AM
Send a message via AIM to loder
same problem
except it stayed at about 3/4. Dealer says it is a faulty gauge.
Old Dec 14th, 2002, 10:58 AM
crunchie's Avatar
I Have got the car booked in for friday 20th, will post my findings.
Crunchie
No engine temperature gauge Stormbreaker Second Generation Faults & Fixes 39 Apr 11th, 2011 08:38 PM
temperature gauge question girasole General Discussion 2 Oct 24th, 2005 05:04 PM
temperature gauge!! ollie c First Generation MINI Cooper S 5 Apr 20th, 2004 08:17 AM
How do I reset the outside temperature gauge? TrueBrtOhio First Generation Faults & Fixes 4 Feb 10th, 2004 11:52 AM
Temperature Gauge Redux tscheez First Generation Faults & Fixes 4 Oct 22nd, 2002 06:06 AM
