Asc light on rev counter - MINI Cooper Forum
Go Back   MINI Cooper Forum > MINI Technical Forums > MINI Faults & Fixes > First Generation Faults & Fixes
Mini Cooper S Loosing power ASC light flashing MiniCooperSSheffield General Discussion 5 Oct 5th, 2013 10:47 PM
Rev counter not working BIG08 Welcome New Members 0 Feb 15th, 2013 08:32 PM
Help! No speedo, rev counter, lights or Mileometer PeteO First Generation MINI One 1 Nov 24th, 2012 08:16 AM
Power failuer to rev counter and speed counter? xtrhardcore First Generation MINI One 2 Aug 16th, 2012 11:04 AM
Old Dec 27th, 2013, 01:26 PM
Thing's Avatar
Local Time: 05:09 AM
England
England Asc light on rev counter
Hi I am after some help! I have got myself a 2001 Mini Cooper that has the ASC light on all the time. I have plugged it into the diagnostics and there is no stored fault codes anywhere on the car and have checked all the abs sensors on live reading and all appear to be working ok. Now I am stumped as there seams to be no diagnostics at all for the ASC system. Has anyone got any ideas? Thanks in advance
Old Dec 30th, 2013, 09:30 AM
Thing's Avatar
England
Has anyone got any ideas? Or even how the system works?
Old Jan 2nd, 2014, 10:24 PM
Thing's Avatar
England
i have found another diagnostics system to plug into and this time i have found 1 fault code:
5E18 CAN data fault from DME/DDE
that wont clear so was wondering if anyone has any idea what the DME/DDE is and if there is a possible fix?
Old Jan 2nd, 2014, 11:05 PM
Local Time: 06:09 AM
Hi ya
It sounds like you may have some damaged wires.
If I was you I would disconnect the battery.
remove the plug from the ABS pump make shore it's clean, dry and no corrosion.
Have a very good look around at the wiring there are problems with chaffing wires around there you may have to remove the battery to get a good look at the wiring.
I would also disconnect the plugs from the DME check them also that there clean, dry and no corrosion and damaged wires.
While the battery is disconnect I would check the plugs on the body control unit these control units tend to throw up some funny faults.
They do suffer form corrosion on the earlier cars always worth checking
Hope this helps out
Old Jan 3rd, 2014, 12:31 AM
Thing's Avatar
England
Thanks marque,
But when you say the DME pulgs is that the engine control module or something else?
i will try and have a poke round at the wiring later at work and hope i can find something
Old Jan 3rd, 2014, 11:40 AM
Hi ya
Yes engine control module is the DME,
There was a recall years back for chaffing wires in the DME ,fuse box, ABS pump area
Here a link about BCU that might be helpfully to
http://www.mini2.com/forum/first-gen...trol-unit.html
Old Jan 3rd, 2014, 04:36 PM
Thing's Avatar
England
Thanks marque
I have checked all the wiring from the abs module to the engine module and all is ok when I check for resistance/broken wire. I have checked my body module to and that is clean and dry too.
Now this is really confusing now and would just love to fix it!
Just a thought could it be an internal fault on the abs module? As I had a close look at the module assembly I have notice it has been replaced before as the brake pipes all got spanner markings from over tightening
Old Jan 7th, 2014, 12:08 AM
Thing's Avatar
England
does anyone know how i can test the abs pump/module to see if it at fault? or is it a trip to the main stealers? everything else seams to be checking out ok so would like to test the abs pump/module
thanks again
» Recent Threads
Help, is this a cooper S??
Yesterday 09:29 PM
by markdm
Last post by markdm
Today 01:29 AM
6 Replies, 133 Views
Cooper S Engine Rebuild
Yesterday 07:44 AM
Last post by marque
Yesterday 11:49 PM
1 Replies, 115 Views
Does your Mini have a name?
Mar 25th, 2014 10:00 PM
Last post by Grumpee1
Yesterday 11:29 PM
18 Replies, 1,073 Views
O2 sensors in exhaust
Yesterday 06:03 PM
Last post by marque
Yesterday 11:24 PM
1 Replies, 80 Views
Mini Cooper S R56 Timing Chain Tensioner
Feb 24th, 2013 11:53 AM
Last post by MCMULC
Yesterday 09:08 PM
9 Replies, 6,672 Views
Just bought mini what extras do I need to tell insurance about
Mar 19th, 2014 03:51 PM
Last post by JohnnyC
Yesterday 07:43 PM
7 Replies, 605 Views
should I wait or not?
Apr 14th, 2014 12:07 AM
Last post by mab01uk
Yesterday 07:10 PM
7 Replies, 434 Views
Constant problems with my R50. Should I keep it or replace? Need advice please
Apr 3rd, 2014 03:52 PM
by kteara
Yesterday 07:03 PM
14 Replies, 911 Views
Spare wheel 55 plate cooper
Yesterday 01:32 PM
by ajn
Yesterday 07:00 PM
2 Replies, 91 Views
Need new rims, any ideas
Apr 8th, 2014 10:14 PM
Last post by CoolioMcPimp
Yesterday 06:44 PM
3 Replies, 309 Views
Cup holder inserts
Yesterday 06:23 PM
Last post by Captain5691
Yesterday 06:23 PM
0 Replies, 69 Views
Electrical Issues with 2003 Cooper base
Mar 10th, 2014 07:09 PM
Last post by The Nun
Yesterday 05:29 PM
3 Replies, 455 Views
Strange Braking Noise
Jan 28th, 2014 08:27 PM
Yesterday 05:22 PM
8 Replies, 966 Views
Mini One D - engine out, how difficult?
Jan 8th, 2014 09:36 PM
Last post by scott132
Yesterday 03:19 PM
3 Replies, 704 Views
R52 A pillar interior trim removal
Yesterday 08:11 AM
Last post by clockworks
Yesterday 02:57 PM
2 Replies, 82 Views
Boot switch not working
Mar 8th, 2014 10:23 AM
Last post by burnstar
Yesterday 11:04 AM
4 Replies, 408 Views
Attention to Detail (UK) - spot the difference!
Yesterday 09:43 AM
by sailesh
Yesterday 10:47 AM
1 Replies, 135 Views
Changing Oil????
Mar 3rd, 2014 12:32 PM
Last post by habi222
Yesterday 09:31 AM
8 Replies, 749 Views
Mini Cooper S Rebuild
Yesterday 07:49 AM
Last post by budgie2014
Yesterday 07:49 AM
0 Replies, 98 Views
Engine mounts
Dec 22nd, 2013 07:47 PM
Last post by johnnycatbiscuit
Yesterday 04:21 AM
3 Replies, 809 Views
Wheel & Tire Center
