Power steering not working & Battery light on (This is a strange one!) - MINI Cooper Forum
Go Back   MINI Cooper Forum > MINI Technical Forums > MINI Faults & Fixes > First Generation Faults & Fixes
R50 power steering pump Rally370 First Generation Faults & Fixes 2 Jul 24th, 2013 02:23 PM
Need advise on power steering failure aioxen First Generation Faults & Fixes 11 May 28th, 2013 02:33 PM
Power Steering problems :( Shelley B First Generation MINI Cooper S 5 Feb 15th, 2013 12:13 PM
No power steering, wipers on, speedometer Pau1GTI Second Generation MINI Cooper 5 Jan 22nd, 2013 10:52 PM
Power Steering pump on the blink...? cooper357 First Generation Faults & Fixes 8 Aug 21st, 2012 10:26 PM
Old Dec 27th, 2013, 03:05 PM
Local Time: 02:27 AM
Hi guys,
so I know this has been asked before countless times but I noticed most of these issues where solved by replacing either the alternator, battery or power steering pump. However my issue might not be this.
Ok so about 6 weeks ago I replaced the gearbox on my 2002 Cooper due to it becoming noisy (A common fault apparently) Anyway when I first started the car when I replaced the box the battery light was on and there was no power steering but it DID work prior with no issues at all. So I took it down the road switched it off and turned it back on. The pump started straight away and I again went down the road. The battery light then started to flicker on/off before being on constantly. When I restarted the car again there was no PAS and the battery light stayed on. So I ignored the problem for the weekend and tried it again and it worked no problem yet again.
So it was no problem for about 5 weeks until now. The problem has come back and I can't get it to go away! I've checked every fuse I can and all the connections, even the 100 amp fuse in the engine compartment thats for the power steering. All seems fine. The battery is also charging no problem at north of 13.5 volts and i've tried another battery on and the issue is still there.
Due to the light originally flickering could this be just a loose connection somewhere? If so where would it be? I understand these Mini's have a 'Sense' wire so if the ecu seems the battery is not charging, it will not activate the pas since its such a high power pump, could this again be the problem?
Old Dec 27th, 2013, 07:22 PM
i would check all ur grounds that u took off i had a similar issue when i changed the clutch in my 08 fiesta i missed one grounding strap and it sent the car mental stuff working and not working as it made contact and then moved put the strap back on to the bell housing and all was fine after
» Recent Threads
Help, is this a cooper S??
Yesterday 09:29 PM
by markdm
Last post by markdm
Today 01:29 AM
6 Replies, 109 Views
Cooper S Engine Rebuild
Yesterday 07:44 AM
Last post by marque
Yesterday 11:49 PM
1 Replies, 105 Views
Does your Mini have a name?
Mar 25th, 2014 10:00 PM
Last post by Grumpee1
Yesterday 11:29 PM
18 Replies, 1,066 Views
O2 sensors in exhaust
Yesterday 06:03 PM
Last post by marque
Yesterday 11:24 PM
1 Replies, 64 Views
Mini Cooper S R56 Timing Chain Tensioner
Feb 24th, 2013 11:53 AM
Last post by MCMULC
Yesterday 09:08 PM
9 Replies, 6,667 Views
Just bought mini what extras do I need to tell insurance about
Mar 19th, 2014 03:51 PM
Last post by JohnnyC
Yesterday 07:43 PM
7 Replies, 599 Views
should I wait or not?
Apr 14th, 2014 12:07 AM
Last post by mab01uk
Yesterday 07:10 PM
7 Replies, 426 Views
Constant problems with my R50. Should I keep it or replace? Need advice please
Apr 3rd, 2014 03:52 PM
by kteara
Yesterday 07:03 PM
14 Replies, 890 Views
Spare wheel 55 plate cooper
Yesterday 01:32 PM
by ajn
Yesterday 07:00 PM
2 Replies, 84 Views
Need new rims, any ideas
Apr 8th, 2014 10:14 PM
Last post by CoolioMcPimp
Yesterday 06:44 PM
3 Replies, 308 Views
Cup holder inserts
Yesterday 06:23 PM
Last post by Captain5691
Yesterday 06:23 PM
0 Replies, 57 Views
Electrical Issues with 2003 Cooper base
Mar 10th, 2014 07:09 PM
Last post by The Nun
Yesterday 05:29 PM
3 Replies, 447 Views
Strange Braking Noise
Jan 28th, 2014 08:27 PM
Yesterday 05:22 PM
8 Replies, 961 Views
Mini One D - engine out, how difficult?
Jan 8th, 2014 09:36 PM
Last post by scott132
Yesterday 03:19 PM
3 Replies, 697 Views
R52 A pillar interior trim removal
Yesterday 08:11 AM
Last post by clockworks
Yesterday 02:57 PM
2 Replies, 75 Views
Boot switch not working
Mar 8th, 2014 10:23 AM
Last post by burnstar
Yesterday 11:04 AM
4 Replies, 402 Views
Attention to Detail (UK) - spot the difference!
Yesterday 09:43 AM
by sailesh
Yesterday 10:47 AM
1 Replies, 125 Views
Changing Oil????
Mar 3rd, 2014 12:32 PM
Last post by habi222
Yesterday 09:31 AM
8 Replies, 742 Views
Mini Cooper S Rebuild
Yesterday 07:49 AM
Last post by budgie2014
Yesterday 07:49 AM
0 Replies, 87 Views
Engine mounts
Dec 22nd, 2013 07:47 PM
Last post by johnnycatbiscuit
Yesterday 04:21 AM
3 Replies, 801 Views
Wheel & Tire Center
