Running water sound? - MINI Cooper Forum
Go Back   MINI Cooper Forum > MINI Technical Forums > MINI Faults & Fixes > First Generation Faults & Fixes
Water under driver's side carpet Hitman70 Second Generation Faults & Fixes 2 Sep 7th, 2013 03:06 PM
water in rear boot floor tool area jonjeffryes Second Generation Faults & Fixes 7 Mar 11th, 2013 02:53 PM
Water in passenger foot well and battery drain boggey79 Second Generation Faults & Fixes 5 Jan 18th, 2013 02:18 AM
Annoying clunking sound from rear! emirius Maintenance & MINI Care 14 Dec 26th, 2012 06:42 AM
Sound and music shut off at high volume with new sub and amp Jonat165 Second Generation Interior & Ice 1 Oct 19th, 2012 03:40 PM
Old Dec 30th, 2013, 01:06 PM
Local Time: 11:08 PM
hi guys,
on start up of the wifes Mini Cooper S, if you listen carefully inside the car, you can quite clearly hear what sounds like running water.
Now we have ongoing issues with the car currently and its due back to the garage in the new year once they re-open but i'm intrigued to know if its a problem, or normal.
Never noticed it before we had all the other issues to be honest
Old Dec 30th, 2013, 07:43 PM
mab01uk's Avatar
Online
Local Time: 12:08 AM
Usually air/gas bubbles circulating in the air con and or heater system......if they blow hot and cold no need to worry.
Old Jan 6th, 2014, 09:51 PM
when you dip the throttle, the water sound then "whooshs". Aircon/heater is off
Old Jan 6th, 2014, 11:02 PM
mab01uk's Avatar
Online
Even though the heater/air con is off this only shuts the ventilation flaps, the heater coolant and/or aircon gas continues to circulate around the system, if engine revs increase the water pump speeds up so this may be the sound you hear as fluid circulation rate increases.
Old Jan 7th, 2014, 03:41 PM
Ah ok, thanks for the feedback.
So can you normally hear this inside a mini cooper S?
I only ask, as never noticed it before, but due to the problems we are having with it, its kind of made it more obvious!
Bear in mind, the car is still mis-firing on start up (and has white smoke coming from the exhaust). It's just had a head gasket change (and had various air leaks prior, which have also been fixed now i think)
Old Jan 7th, 2014, 10:16 PM
mab01uk's Avatar
Online
Some seem to make this sound occasionally without any other issues but if it is excessive it could perhaps be related to your other problems.....any feedback from the garage yet?
Old Jan 9th, 2014, 11:18 AM
going back into the garage this weekend, so fingers crossed. The wife is absolutely gutted, its her dream car.
Gunmetal grey (or whatever the name is), only done 33,000 miles (2003 plate)
Old Jan 21st, 2014, 08:08 PM
Well.......The garage think it might have a cracked block and thats why the car is still misfiring/blowing white smoke......
Bah.....
Old Jan 21st, 2014, 10:07 PM
mab01uk's Avatar
Online
Sounds a bit drastic......maybe worth getting a second opinion from an independent Mini specialist?
Old Jan 22nd, 2014, 12:02 PM
it's been to the local mini garage (the garage the car is with, took it there as they know someone who works there).
Re-conditioned engine is the next step (the place i bought the car is footing the bill thankfully)
» Recent Threads
Offically The World's Quickest & Fastest MINI
Mar 4th, 2014 10:50 PM
by mab01uk
Last post by mab01uk
Today 11:01 PM
7 Replies, 1,069 Views
Is Mini not good for long trips?
Today 12:58 PM
Today 10:51 PM
6 Replies, 171 Views
Tow Hitch for '13 Roadster
Feb 17th, 2014 05:56 AM
Last post by Mid Life Mini
Today 09:22 PM
6 Replies, 491 Views
Tunning a mini cooper Saround ESSEX??
Today 09:04 PM
Last post by johnd-mkiv
Today 09:04 PM
0 Replies, 37 Views
Fuel Guage stopped working
Mar 17th, 2009 10:26 PM
by SRRAE
Last post by phong13
Today 08:45 PM
1 Replies, 392 Views
Does your Mini have a name?
Mar 25th, 2014 10:00 PM
Last post by race4aliving
Today 07:36 PM
32 Replies, 1,697 Views
Wanna! Watch Neighbors Movie 2014 Online
Today 05:30 PM
Last post by johnpogue2014
Today 05:30 PM
0 Replies, 53 Views
R53 GPS and Head Unit qs.
Today 01:17 PM
Last post by heathwebbo
Today 05:23 PM
1 Replies, 94 Views
Cooper R50 rally lamp/fog light bulb type?
Today 12:04 PM
Last post by Challinor
Today 04:46 PM
2 Replies, 104 Views
Low quality lounge leather? Retro better?
Today 04:11 PM
by rvt50
Last post by rvt50
Today 04:11 PM
0 Replies, 100 Views
Mini ONE 2006 Head Unit, Harman Kardon, Sat Nav??
Today 02:53 PM
by gumbsy1
Last post by gumbsy1
Today 03:03 PM
1 Replies, 109 Views
Radio CD Player Spare Part
Apr 17th, 2014 10:47 AM
by B20A
Today 02:56 PM
2 Replies, 180 Views
Mini Cooper R56 Radio Problem
Apr 1st, 2013 05:38 PM
Last post by gm_MiniCoopsta
Today 01:45 PM
1 Replies, 1,065 Views
should I wait or not?
Apr 14th, 2014 12:07 AM
Last post by CoolioMcPimp
Today 01:37 PM
9 Replies, 648 Views
Help with fault codes!
Oct 17th, 2008 06:38 PM
Last post by sepiareverb
Today 01:12 PM
7 Replies, 28,778 Views
Car seat for toddler
Aug 6th, 2011 07:59 PM
Last post by habi222
Today 12:02 PM
3 Replies, 3,900 Views
Baby seat for MCS R53??
Feb 1st, 2012 12:20 PM
by Slaydo
Today 11:58 AM
1 Replies, 1,585 Views
Child Seat for a MCS 2003 - Seatbelt
Mar 19th, 2012 01:06 PM
Today 11:46 AM
1 Replies, 1,194 Views
Wheel & Tire Center
