R53 oil pressure light - MINI Cooper Forum
post #1 of 4 (permalink) Old Jan 10th, 2014, 05:06 PM Thread Starter
Local Time: 08:17 AM
Quoted: 1 Post(s)
Hi.
I have a 2003 Mini Cooper S. After driving the car for about 10mins the oil pressure warning light will come on when at idle. It then goes out if the revs come up. Driving it further the rpm which the light comes on at increases up to 2000rpm.
If I turn the car off for even just minutes the problem goes away until I have been driving for another 10mins.
Anybody have any idea what this could be.
I'm thinking it could be the pressure relief valve??
Obviously I have check the oil level which is ok and also replaced with new.
barcs86 is offline
post #2 of 4 (permalink) Old Feb 18th, 2015, 01:25 PM
Registered User
Thumbs up Same issue
Hello barcs86,
Since yesterday, I'll face exactly the same issue. I check the oil level, add some (now, the gauge is upper the max graduation), check the oil filter housing (nothing missing or gone - plastic guide/springs) and... the light still come on, as soon as the car runs under 2000rpms !!!
Did you find something ? I think I will replace the pressure sensor... (but half hearted... since it's just a contact with a ball and a spring)
Let me know please, if you find something. Cheers (and good luck ;-)
titi38 is offline
post #3 of 4 (permalink) Old Feb 18th, 2015, 04:39 PM
Local Time: 09:17 AM
Quoted: 53 Post(s)
It could of course be just worn out engine bearings?
The oil reaches a certain temperature, its thinner, lower oil pressure, the light comes on, it does happen in the end.
The Nun is offline
post #4 of 4 (permalink) Old Feb 18th, 2015, 05:22 PM
Quoted: 4 Post(s)
Garage
Originally Posted by barcs86 View Post
Hi.
Hi, as titi38 mentions, I would jump on the Oil Pressure Switch first. They are very basic, but carbon build up can cause a problem. Obviously good oil and a regular filter change is very important, especially on older engines, its not just about the mileage, time in service matters too! Pressure release valve would also be a good investigation, I have never had a problem with BMW Mini's, but with the old A and B Engines of the past Mini and MG, I have had similar issues. Apart from an electrical issue, the other factor could be a lazy oil pump. You could check to see if your Valve gear is nice and wet with oil, if not it is most likely a problem with the oil not getting to where it needs to be.............low pressure or restriction.
Good luck, make sure you post your findings!!!
R53WithOne is offline
Oil pressure light GoldenWonder Maintenance & MINI Care 0 Sep 26th, 2013 11:29 AM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 10:23 AM
Oil Pressure Light After Oil Change NICK@NUMBER11 First Generation Faults & Fixes 7 Feb 22nd, 2013 10:37 AM
Oil light dregsa First Generation Faults & Fixes 3 Jan 29th, 2013 10:40 PM
Help me please! Tyre pressure light on - not sure what to do? AmyVee Wheels, Tyres & Brakes 7 Aug 31st, 2012 04:25 PM
