| Re: FFFFFFFFFFFFFFFFT acceleration noise. From what you describe, it sounds like it could be some sort of exhaust leak. + 2002 MINI Cooper S - Dark Silver / White roof, Sport, Premium, Lapis blue leather + 1965 Mini Traveller - Tartan Red / White roof, 1275, Cooper S discs, fully restored/renewed |
| Well, based upon my previous experiences with exhaust leaks (if that really is what your car has) I think the engine might need to be under load pressurizing the exhaust system if it is just a small leak. With the engine just idling you may not hear it. + 2002 MINI Cooper S - Dark Silver / White roof, Sport, Premium, Lapis blue leather + 1965 Mini Traveller - Tartan Red / White roof, 1275, Cooper S discs, fully restored/renewed |
| Sounds similar to a problem I had a few months ago on my Cooper. Never thought the dealer would succeed in tracking it down but they did. Turned out to be a split grommet/seal in the bulk-head by the driver's side footwell. I think it was where the accelerator cable went through and the split in the seal tended to open up as the pedal was depressed. No more "FFFFFFFFFFFTing" now! Hope this helps. PWB |
| It was very much intermittent, with no apparent common cause. That's why I was so amazed when my dealer tracked it down and cured it. Maybe it's actually a known problem so they knew where to look!! Good luck with yours GMINI. |
| No whistle with mine, just a soft wind-rush noise - or, as you previously put it a ffffffffffffffffffffffffffft! It was certainly speed/acceleration-dependent and, possibly, temperature-dependent - the latter could have explained the intermittent nature of it. Hope you track it down - it's damned annoying if you don't want to have the stereo cranked-up the whole time to drown it out. |
| Yes it does... The supercharger incorporates a specially designed bypass valve. This is actuated by a vacuum pipe near the throttle body and re-circulates the supercharged air when there is a depression in the manifold and therefore when boost is not required. Cheers |
| Re: FFFFFFFFFFFFFFFFT acceleration noise. There is a seal around the intake Plenum on the supercharger.I have replaced a few of these.What you are hearing is compressed air leaking from the super charger under throttle application.This noise can be easily listened to from the outside of the vehicle or by turning the ignition of. |
| 05 mcs 'Ratchet/scratching?' noise on accel' and de-acceleration | mamba | First Generation Faults & Fixes | 8 | Jun 22nd, 2005 01:23 AM |
| Flutter/Warble Noise Under Hard Acceleration | Gavin1 | First Generation Faults & Fixes | 2 | Apr 22nd, 2005 11:18 PM |
| anyone had a whistle noise on cold acceleration -? Cooper | BartMack | First Generation Faults & Fixes | 17 | Jan 26th, 2005 03:44 AM |
| Groaning noise on acceleration when cold? | oldskoolflash | First Generation Faults & Fixes | 4 | Jan 22nd, 2005 06:01 PM |
| noise noise and more noise (wheel bearings?) | eddie_DV52_CCZ | First Generation Faults & Fixes | 2 | May 22nd, 2004 10:28 AM |
