Drivers-side Xenon - MINI Cooper Forum
post #1 of 3 (permalink) Old Jan 27th, 2014, 02:44 PM Thread Starter
Local Time: 03:20 AM
England Male
Drivers-side Xenon
Got a problem with my 2002 R53.
The drivers side Xenon stopped working suddenly.
Ive swapped the bulbs and ballasts from the passenger side and the fault remains.
Reading around here, it could be the ignitor in the lamp itself - also been told its the BC1 unit or whatever its called. Cant imagine its the latter as everything else electrical is fine. Also been told to check the wiring to see if the light is getting power to it... Is this possible as i thought you shouldn't try with that amount of voltage!
Any ideas what else to check?
Really cant afford to keep chucking money at this car so any help would be appreciated.
Hollywood is offline
post #2 of 3 (permalink) Old Jan 27th, 2014, 06:47 PM
Local Time: 02:20 AM
Hi ya
I know you say your xenon light does not work but Does your high beam work ?
If not
Have you checked that the earths points are ok, also have you checked the fuses in the engine bay fuse box FL8 and FL12 I think.
The engine bay fuse boxes are a known problem area with chaffing wires underneath and the fuse box internals rot and short out.
If the fuses are ok you are going go need to start to check for voltage and start chasing wiring
It is possible it could be the BCU but do the easy cheep stuff first
Hope this helps
marque is offline
post #3 of 3 (permalink) Old Feb 6th, 2014, 07:49 AM Thread Starter
England Male
Thanks, Marque. Appreciate your help.
Slight update - it started working by itself last week haha!
I was just about to order a new lamp!
Tags: , , , ,
Xenon headlamps Hollywood First Generation Faults & Fixes 0 Jan 21st, 2014 12:50 PM
Water under driver's side carpet Hitman70 Second Generation Faults & Fixes 2 Sep 7th, 2013 03:06 PM
Mini C 2002 - Driver side xenon gone thedynamix First Generation Faults & Fixes 5 Apr 2nd, 2013 02:02 PM
Nocking noise from drivers side 04 Cooper S Dancoopers First Generation Faults & Fixes 8 Mar 27th, 2013 07:13 PM
MINI ONE crunching and knocking on drivers side captain_az General Discussion 0 Oct 11th, 2012 08:22 AM
