newbie needs help pleasep1242 - MINI Cooper Forum
post #1 of 5 (permalink) Old Feb 7th, 2014, 09:02 PM Thread Starter
Local Time: 02:08 PM
hi guys
new too forum really need some help keep getting p1242 code on my obd reader put it in google come up with
P1242- Secondary upstream manifold air pressure too high in deceleration
which is great but i don't have a great knowledge of cars and wonderd if anyone could tell me if its an easy repair like a sensor or something also are they any free online workshop manuals
the car is a cooper s 55 plate 2005
thanks ryan
topboy11 is offline
post #2 of 5 (permalink) Old Feb 7th, 2014, 09:43 PM
Hi ya
Sounds like you TMAP sensor is playing up, I would pull the pug off and give it a clean out with wd40 or similar make shore it's not wet with all the rain we have had recently
If your not shore where your TMAP sensor is open the bonnet look at your intercooler cover you will see it at 6 oclock position ish there are two connectors there the one going left to right is your knock sensor connector the other is your TMAP sensor.
If the plug is ok you may have to remove the sensor only two bolts and clean it carefully. If not you may have to replace it.
I would try to borrow one before splashing out on one just Incase the problem is somewhere else
Where are you in uk
Hope this is of help
marque is offline
post #3 of 5 (permalink) Old Feb 8th, 2014, 02:50 PM Thread Starter
thanks for replaying
i live in croydon area
will try the above today or tomorrow weather depending
it has happened since i had the clutch changed maybe a coincidence I'm not sure thanks for help will try and post back findings
topboy11 is offline
post #4 of 5 (permalink) Old Feb 8th, 2014, 02:53 PM Thread Starter
sorry should i clean the sensor with wd40 also
the problem with borrowing a sensor is that sometimes it take around 2-4days to come on are they expensive to buy
topboy11 is offline
post #5 of 5 (permalink) Old Jul 20th, 2015, 05:31 PM
1242 / 0036 issue
im having this: 1242 - pressure sensor, intake manifold befpre compressor-input too low with trailing throttle
0036 - heated oxygen sensor, heating circuit (bank 1, after cat.)-malfunction
All started after i replace the charger oil and actuator spring in my r53. It was running well before this check light pops up. When the light pops up, the engine has a big vibration. Even after i clear the error, the vibration is still there. The mech check for any leaking with a leaking detector and there was no leak detected beside the engine oil cap. Is there any other thing i should check before replacing the sensor with a new module?
Stanley Rocky Meadow is offline
Where Did the Oil Go ? Newbie needs Advice breyfogle Maintenance & MINI Care 6 Mar 11th, 2013 10:40 AM
Newest Newbie William Woodcock Welcome New Members 0 Jan 15th, 2013 01:57 AM
Another newbie!! #Curt Welcome New Members 1 Jan 14th, 2013 11:52 PM
Newbie w/ stock 2007 soccrscot11 Welcome New Members 0 Oct 30th, 2012 01:24 AM
