mini cooper indicators+brake+reverse lights not working :/ - MINI Cooper Forum
post #1 of 10 (permalink) Old Feb 12th, 2014, 09:37 PM Thread Starter
Local Time: 05:24 AM
hi, my cooper rear break and reverse lights do not seem to come on for some strange reason, apart from the brake light on the bootlid. also my indicators are flashing on dials inside but nothing on the outside. have checked fuses by passengers side and all seem intact, also the abs light is remaining on which is strange unless one of the sensors have managed to go bad. if somebody could shed some light on this problem it will be much appreciated. cheers
cooper1786 is offline
post #2 of 10 (permalink) Old Feb 14th, 2014, 03:56 AM Thread Starter
any help will be appreciated.
post #3 of 10 (permalink) Old Feb 19th, 2014, 04:03 AM Thread Starter
282 views later and still not a reply to either of 2 posts :/
post #4 of 10 (permalink) Old Feb 19th, 2014, 04:48 PM
Hi ya
Sounds like your body control unit is playing up due to water ingress, the body control unit is located in the drivers footwell you need to disconnect the battery remove and clean the plugs and terminals on the BCU .
Hope this helps
marque is offline
post #5 of 10 (permalink) Old Feb 19th, 2014, 06:15 PM
mab01uk's Avatar
Quoted: 2 Post(s)
Also check wiring in boot for CD changer, even if you don't have a CD changer the wiring is there pre-wired and if the unused connector shorts out due to damp, etc, strange electrical glitches happen.
mab01uk is offline
post #6 of 10 (permalink) Old Feb 19th, 2014, 06:23 PM
:-) just about to edit that in mab01uk :-) you beet me to it :-) I was also thinking may be bad earth points in the boot
Hope this helps
marque is offline
post #7 of 10 (permalink) Old Feb 19th, 2014, 07:03 PM Thread Starter
Hi cheers for the replies, I've taken out the BC unit and it was completely dry and rust free, also has the plastic cover over the top to stop water drips. There is no CD changer installed so where would I find the connection and earth points if you can point this iit please. Cheers
post #8 of 10 (permalink) Old Feb 19th, 2014, 09:53 PM
Hi ya
If you open the boot up there is access panels on each side to get in to change bulbs open them up there should be earth modules there one each side. Look forwards
Just a though you have been though the fuse box to make shore the fuses are ok.
I don't know if you have access to bmw DIS diagnostic machine you could run a check on The BCU to make shore it is ok
Hope this helps
Ps if you have a cd changer fitted if fits in the boot on the right hand side right by the access panel
marque is offline
post #9 of 10 (permalink) Old Feb 19th, 2014, 10:13 PM Thread Starter
thanks for that marque, is it where there is brown wires going to? and all fuses are working as i checked these earlier, wonder if its a relay but not too sure? also i dont have access to a diagnostic machine but will have it put on machine at local garage just to make sure.
post #10 of 10 (permalink) Old Feb 18th, 2015, 01:25 AM
Hi,
Not to sure how old this thread is but I am having the same problem.
I have had a diagnosis done and was told it is due to the body control unit which needs changing.
I haven't yet had the work done as I need to find the part second hand myself cause don't want these garages ripping me off.
Did you sort your problem???
Biancamini04 is offline
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 03:15 PM
2014 MINI Cooper S Revealed in Spy Photos AutoGuide.com MINI News 14 Jan 13th, 2015 07:58 PM
Brake lights not working Bigyin1980 First Generation Faults & Fixes 2 Mar 20th, 2014 07:57 PM
Mini Australia service chilld Dealership Feedback 4 Sep 4th, 2012 05:29 AM
