Convertible rear sensor replacement - MINI Cooper Forum
post #1 of 2 (permalink) Old Feb 16th, 2014, 03:47 PM Thread Starter
Local Time: 03:57 AM
Quoted: 79 Post(s)
One of my rear sensors had failed on my MCS convertible and there was no clear how to guide to help me remove and replace it.
Sorry no pictures, but this should clear up a few points.
1) a failed sensor does not click when the system is working.
2) the rear bumper does not need to be removed from the car, but all the fasteners need to be removed to allow it to be moved.
3) the sensors push back to release them and push in from the back of the bumper to fit
Remove the bumper fasteners:
Two by the rear lights inside the boot opening
One under the car to the drivers side of the exhaust
One each side under the rear arch trims
One each side at the back of the wheel arch (jack the car up to make access easier)
Remove the trims behind the hinges by pushing them inwards and up.
Pull the bumper out at the top and sides
Lie under the car and pull the bumper out away from the car and you'll see the sensors.
Unclip the faulty sensor, two prongs opposite the plug, and push back from the outside of the bumper.
Remove the sensor and unplug it (it's easier to unplug it when it's hanging down)
Plug in the new the new sensor
Test to make sure all is working
Refitting is the opposite of the above.
You'll need about 30 mins in total. The job is easier that you think.
Hope this helps.
I paid 15 for the sensor and 5 for the touch up paint to colour code it. Worth a bit of DIY on a Sunday in my eyes.
k3fus is offline
post #2 of 2 (permalink) Old Feb 16th, 2014, 05:17 PM
...opinionated!
Deep_27a's Avatar
Local Time: 04:57 AM
United Kingdom Male View Deep_27a's  &  2nd Gen  Profile View Deep_27a's Classified Ads
Thanks for sharing this
More fault fixes please!
Deep_27a is offline
Rear seat wet Mini R57 Convertible leak damp Mrs Bear Second Generation MINI Convertible 6 Mar 9th, 2015 06:40 PM
convertible heated rear window not working Redcooperclubman First Generation MINI Convertible 2 Dec 26th, 2013 03:56 PM
MCS Clubman rear parking distance control juge Second Generation Faults & Fixes 1 Dec 14th, 2013 03:12 PM
F57 MINI Convertible - Photos mab01uk MINI in the Media 0 Nov 6th, 2013 11:30 PM
Rear Bumper for Mini Convertible Dazzahooz General Discussion 2 Sep 27th, 2012 12:04 AM
