Cooper S ABS light flickering after start up? - MINI Cooper Forum
post #1 of 2 (permalink) Old Feb 19th, 2014, 04:00 PM Thread Starter
Local Time: 11:02 AM
Hello one and all,
3 days ago my 2002 Mini Cooper S developed a strange fault with the abs. After the car is started and as you pull away in 1st gear at a slow pace (no spinning) the abs light flickers and kicks in for a few seconds then clears, after that it is fine and would be for 500 miles hypothetically. It only seems to happen when the car is turned off, turned back on and then it kicks in when you pull away. The car has been plugged in, which came back all clear so no sensors are down etc.. Even if there was a magnet down on the driveshaft surely it would continually do it? All the tyres pressure have been checked and all running the same psi, I have even disconnected the battery for 20 mins, still no joy..
All help will be gratefully appreciated,
Woddy is offline
post #2 of 2 (permalink) Old Feb 19th, 2014, 05:50 PM
Local Time: 12:02 PM
Quoted: 1 Post(s)
If it was me I'd get the wheels off and spray clean the sensors.
But be carefully last time I messed around with one I 4t I'd take it out and clean it, I snapped it!! Wasnt a big issue as it drills out rather easy but you'll have to buy another.
There about 50 after market
James burbidge is offline
R56 Cooper S will not start xtwister161 Second Generation Faults & Fixes 0 Feb 12th, 2014 04:39 AM
ABS light, Hand brake light copey General Discussion 4 Jan 6th, 2014 06:20 AM
Mini Cooper r53 acs, abs and tyre light rossib86 General Discussion 4 Jan 13th, 2013 08:23 PM
'07 cooper s wont start after loose tensioner. Timing? geekycraig Maintenance & MINI Care 0 Oct 3rd, 2012 06:03 PM
abs light on handbrake light on gp2003 General Discussion 1 Aug 14th, 2012 04:24 AM
