Helicopter sound coming from rear? - MINI Cooper Forum
post #1 of 9 (permalink) Old Feb 25th, 2014, 12:58 PM Thread Starter
Local Time: 09:11 AM
I have 2002 mini cooper s, I have been hearing the helicopter take off sound for a while now, it's only when I get up to a high speed at 60 or 70 mph, I thought it could be a gearbox problem but when I'm driving I put in nuetral the helicopter sound is still there. Anyone know the problem rather not go to dealer!!!
Lakilimited is offline
post #2 of 9 (permalink) Old Feb 25th, 2014, 01:44 PM
Local Time: 01:11 PM
Check your rear tyres for damage or irregular wear, after that it could be a wheel/tyre balance issue. Could also be a worn wheel bearing, is it worse/louder when taking a corner?
Big_Nige is offline
post #3 of 9 (permalink) Old Feb 25th, 2014, 09:24 PM Thread Starter
The sound is in the rear so when I turn it sounds the same I checked the wheel to see if it was loose to see if the wheel/hub bearing was bad but was perfectly fine and no real odd wearin my tires either.
post #4 of 9 (permalink) Old Feb 26th, 2014, 06:23 AM
heathwebbo's Avatar
Could be a buckled wheel can you feel any vibration when its making the noise although what big nige said sounds more likely. Normally if a rear wheel bearing is on its way out it gets louder when you go round corners thats what big nige meant, as the weight shifts you hear it more
heathwebbo is offline
post #5 of 9 (permalink) Old Feb 26th, 2014, 11:22 AM
Local Time: 12:11 AM
Quoted: 1 Post(s)
Australia Male
Maybe worth checking to ensure you haven't got loose body parts eg: bumper / trim / rear number plate / number plate cover / mudflaps (if fitted) / muffler heatshield or even the plastic rear wheel liner etc - or something that is flapping around from air pressure when you get some speed up?
Crawl underneath and give them all a wiggle by hand & check all is secure.
jj-snax is offline
post #6 of 9 (permalink) Old Feb 26th, 2014, 02:38 PM
Has the car been stood a while for any amount of time? Tyres do easily flat spot within a short space of time.
Get the car to a tyre fitters and have them balance the rear wheels, it's quite an inexpensive exercise.
Big_Nige is offline
post #7 of 9 (permalink) Old Feb 28th, 2014, 08:43 PM
Local Time: 02:11 PM
Wales
I have something similar and have traced it to the plastic wheel arch liner not fitted properly and is catching the outside edge of the tyre when cornering. Its the off side rear so is only noticeable with a rear passenger and going round left handers.
gixer181 is offline
post #8 of 9 (permalink) Old Mar 1st, 2014, 08:20 AM
ALD0's Avatar
Quoted: 1 Post(s)
Wheel bearing for sure.
ALD0 is offline
post #9 of 9 (permalink) Old Mar 1st, 2014, 09:53 AM
I'd say wheel bearing too!
MKDude is offline
MCS Clubman rear parking distance control juge Second Generation Faults & Fixes 1 Dec 14th, 2013 02:12 PM
2007 MCS R56 boot open warning light/message on dash, squeal & rear wiper not working LadyUK Second Generation Faults & Fixes 3 Oct 31st, 2013 05:27 PM
"Crunchy" squishy loud sound coming from the wheel when I turn grozenblat First Generation MINI Cooper S 0 Mar 11th, 2013 11:11 PM
Annoying clunking sound from rear! emirius Maintenance & MINI Care 14 Dec 26th, 2012 06:42 AM
Ticking sound coming from automatic Chrome ring surround Kjedesign General Discussion 0 Nov 30th, 2012 05:10 PM
