Iratating rattle - MINI Cooper Forum
post #1 of 4 (permalink) Old Mar 5th, 2014, 07:21 PM Thread Starter
Local Time: 08:43 AM
Iratating rattle
Ive got a plasticky sounding rattle coming from somewhere under the footwell of the drivers side of my mini,dunno why just occurred over the last few days, can't hear it when I'm on a decent road, just potholey ones and rough ones....getting annoying....any ideas where it might be coming from???
Josimo41 is offline
post #2 of 4 (permalink) Old Mar 5th, 2014, 10:31 PM
Local Time: 09:43 AM
Could be anything. My mini with extremely stiff suspension rattles on uneven road surfaces as well. If it is under the driver side footwell, you can unclip the plastic bit underneath the steering wheel. With a fair bit of force, place your hand in the gap near the steering wheel adjustment lever and then pull it towards you. There is a clip on each side of the steering wheel, start with the one on the side of the stereo. Once open you should be able to use a torch to see if anything has come loose such as a screw, or if another item fell into the area.
Kalenshah is offline
post #3 of 4 (permalink) Old Mar 6th, 2014, 06:37 AM Thread Starter
Thanks,, I will try that this morning, really don't want to get to the stage where I end up taking the whole dash out! Lol!
Josimo41 is offline
post #4 of 4 (permalink) Old Mar 6th, 2014, 07:01 AM
I bought a 2014 Clubman S back in October. At about 2500 miles, my car also developed a rattle on the left side somewhere. The driver window squeaks, and the headliner buzzes. The sunroof whistles on the highway. Unfortunately, it all seems to be intermittent. The steering also loosened up considerably, so it's quite sloppy around corners, and there is no on-center feel. This is my first mini, and although I was impressed at first, it seems to be badly built and already coming apart. The dealer fiddled with the sunroof, but no improvement.
spiritof76 is offline
So, when is a death rattle not a death rattle? -ralph- Second Generation MINI Cooper 12 Jan 25th, 2014 02:09 PM
Rattle in speedo Ken White Second Generation Works 8 Jan 11th, 2013 08:27 PM
Cooper S Rattle when pulling off? cupofjavaa General Discussion 14 Dec 12th, 2012 01:51 AM
2007 MCS Cold start rattle under load. Specific rpm. JGrimshaw Second Generation Faults & Fixes 3 Nov 22nd, 2012 07:27 PM
rattle. revs up and down, cold start, backfire, jerking misterdarkness Second Generation Faults & Fixes 1 Oct 20th, 2012 01:02 AM
