Small water leak only in the morning - MINI Cooper Forum
post #1 of 12 (permalink) Old Mar 18th, 2014, 03:49 PM Thread Starter
Local Time: 09:31 PM
Hi I am new to the forum and thanks in advance for any replies
I have recently noticed when my car is left overnight on the driveway that there is a small wet patch of wTer coming from the edge of the bumper. This has now happened 2 days running. After I start the engine i can see small droplets of water running down, it usually will leak for about a minitue or so then stop completely and will not leak throughout the whole day.
Could it be a leak in the raidiator? Or could it be the thermostat leaking?
Also my car usually warms up quick and gets half way up the temp gauge but as its been slightly hotter the last few days I've noticed it reach half way temp a lot sooner it makes sense right? It's just usually on my older cars it used to take a little longer to reach half way on the temp gauge.
akaymc is offline
post #2 of 12 (permalink) Old Mar 18th, 2014, 04:33 PM
Local Time: 10:31 PM
Was your car wet when you put it in the garage? I get this sometimes when my car is parked in the garage overnight and is still wet.
Kalenshah is offline
post #3 of 12 (permalink) Old Mar 18th, 2014, 04:55 PM
Quoted: 53 Post(s)
Is the water pure water? as if it was coolant it would smell and have a colour too it, dont confuse it with cats pee please if youre going to taste it though.
But it can be a coolant leak when cold that will seal, up to a point once hot.
Check you coolant level in the header tank, has it dropped?
It could be a leaking headlight wash hose even or screen wash bottle, but that will also smell if its got the additive in it that is should always have?
Or it could just be morning dampness running down from a gutter but that will just be pure water?
Better get down on your knees and taste some, and watch the neighbours arent looking.
The Nun is offline
post #4 of 12 (permalink) Old Mar 18th, 2014, 04:59 PM Thread Starter
Lol it's not pee.
It's defo water as I put my hand under the bumper where it was dropping from and it seems like water with no colour. Where do I check my coolant level? Is it the same place where I refill my water for radiator?
akaymc is offline
post #5 of 12 (permalink) Old Mar 18th, 2014, 05:06 PM
Quoted: 53 Post(s)
Check your coolant level at the expansion bottle, should tell you in your very handy drivers handbook that you should always have to hand?
Or take the top off where you normally fill it and have a look, does it look low or empty even?
The Nun is offline
post #6 of 12 (permalink) Old Mar 18th, 2014, 05:23 PM Thread Starter
It's filled up almost to max but when I first noticed the leak it was just slightly low I had to fill up about a litre of water to get it to top level again ever since its hardly lost an water.
akaymc is offline
post #7 of 12 (permalink) Old Mar 19th, 2014, 10:57 AM
Quoted: 24 Post(s)
Does your MINI have air-conditioning?
Spike
ihughes is offline
post #8 of 12 (permalink) Old Mar 19th, 2014, 04:12 PM Thread Starter
Yes it has air con
akaymc is offline
post #9 of 12 (permalink) Old Mar 19th, 2014, 05:07 PM
Quoted: 24 Post(s)
Are you sure the water isn't coming from the air con condenser drain......this will dump clean water on the road pretty much every time you start the car when it has been standing overnight ?
Spike
ihughes is offline
post #10 of 12 (permalink) Old Mar 20th, 2014, 04:30 PM Thread Starter
i dont think so.
I have spotted a place on the raidiator where i think its leaking from as its dropping water very slowly and you can see its wet there. ive took a few pics but it wont let me upload just yet.
its coming from the corner of the rad, drivers side.
akaymc is offline
post #11 of 12 (permalink) Old Mar 20th, 2014, 04:41 PM
Quoted: 40 Post(s)
Worth a trip to the doctor to see if it's a symptom of something else......
Angib is offline
post #12 of 12 (permalink) Old Mar 20th, 2014, 07:43 PM
mab01uk's Avatar
Quoted: 1 Post(s)
Originally Posted by akaymc View Post
i dont think so.
Corners of the Mini radiator are very common slow leak points so I guess this is your problem....replacement Mini rads are supposed to be improved and somtimes need a new type of hose to be fitted to match.
mab01uk is offline
couple of problems, dash electrics and water leak asmith88 First Generation Faults & Fixes 17 Dec 20th, 2013 06:58 PM
Water leak from rear view mirror (and surrounding area)? edwardtobia First Generation Faults & Fixes 3 Nov 29th, 2013 07:24 AM
Water under driver's side carpet Hitman70 Second Generation Faults & Fixes 2 Sep 7th, 2013 03:06 PM
Water leak Hollywood First Generation Interior & Ice 2 Aug 7th, 2013 12:45 PM
Door water leak! rachwil888 First Generation MINI Convertible 5 Mar 25th, 2013 02:49 PM
