Run Flat & DSC lights always on? - MINI Cooper Forum
Go Back   MINI Cooper Forum > MINI Technical Forums > MINI Faults & Fixes > First Generation Faults & Fixes
Run Flat Warning display Paulstar808 General Discussion 1 Feb 2nd, 2014 05:38 PM
run flat light and mot asmith88 First Generation Faults & Fixes 3 Dec 5th, 2013 06:21 PM
abs, asc, run flat and handbrake lights WesR50 First Generation Faults & Fixes 0 Dec 2nd, 2013 04:27 AM
Run Flat Question samowens Wheels, Tyres & Brakes 1 Jul 13th, 2013 09:09 AM
Run Flat Tyres & Dash Indicator and standard wheels? stargirl169 Wheels, Tyres & Brakes 6 Jan 29th, 2013 07:46 PM
Old Mar 20th, 2014, 11:17 AM
Local Time: 11:17 AM
England Run Flat & DSC lights always on?
Hi my wife's mini cooper s 2003 has started showing 2 lights (on constantly)
The run flat light and also the DSC light? My first assumption was one of the 'wheel speed sensors' so like an idiot (without actually knowing what the fault was, I bought 2 front wheel speed sensors)
After a phone call with my local bmw dealer I learnt just to diagnose the fault was going to cost me £121.00!! So I bought my own cheap fault code scanner (C110 BMW CODE SCANNER).
It arrived today and so i've just had it hooked up to the car.
I am now none the wiser!
Is a 'rotation rate sensor' just another word for 'wheel speed sensor'? or is this a different part altogether?
These are the codes that it has given me:
5E1F : 'Vehicle Identification Number Different' ........ Different to what??!!
5E16 : 'CAN Connection to instrument cluster' ......... meaning what?
5E19 : 'CAN data fault from DME/DDE (DSC lamp on as long as error is present)'
5E5C : 'Initialize Run Flat Indicator, see owners handbook'
5E38 : 'Rotation Rate Sensor'
Has anyone got any ideas or is it just a case of a process of elimination?
any help would be GREATLY appreciated.
I have added pictures of the 2 lights that are on and also the scanner results, (looks like I haven't as I haven't made 15 posts or more!)
Thanks in advance
Luke
Old Mar 22nd, 2014, 12:30 PM
Anyone have any ideas?
Old Mar 22nd, 2014, 01:07 PM
heathwebbo's Avatar
Online
Local Time: 10:17 AM
Not sure on this but I think I read a while back it could be the steering angle sensor
Old Mar 25th, 2014, 09:56 PM
Ok how about I make it a bit simpler......
Does anyone know what a 'rotation rate sensor' is?
Old Mar 26th, 2014, 03:01 PM
cristo's Avatar
BLIKSEM (my brg/brg mc)
Local Time: 06:17 AM
United States Male View cristo's British Racing Green & Body Color 1st Gen MINI Cooper Profile
Rotation rate sensor would be the ABS sensor A.K.A. the wheel speed sensor.
Could well be one of the rear wheel speed sensors, since replacing the front's didn't fix it.
You can disconnect each one and test the resistance and see which is off, or hook it up
to a analog multimeter or scope and spin the wheel and look for the proper pulse signal
to troubleshoot which one is bad.
Steering angle sensor fault is 5E43.
» Recent Threads
Parking Sensor ECU
Today 09:59 AM
Last post by archerluke
Today 09:59 AM
0 Replies, 1 Views
Need a new key ** New Member **
Apr 29th, 2014 01:10 PM
Last post by mab01uk
Today 09:11 AM
7 Replies, 822 Views
AGM Battery
Mar 28th, 2013 10:06 AM
Last post by bob8
Today 08:25 AM
8 Replies, 3,868 Views
Halo Hedlights??
Today 04:25 AM
by dsakko
Last post by dsakko
Today 06:54 AM
2 Replies, 90 Views
Fan coming on when engine cold and staying on after engine turned off
Aug 26th, 2014 10:08 PM
Last post by BlueBeastie
Today 04:40 AM
2 Replies, 465 Views
R50 Problems, how common?
Aug 10th, 2014 11:08 AM
by aypea
Last post by dsakko
Today 04:29 AM
5 Replies, 662 Views
Weather tech floor mats?
Today 03:11 AM
by tcam33
Last post by tcam33
Today 03:11 AM
0 Replies, 103 Views
iPhone 5s on a Mini Cooper S (2009)
Yesterday 09:44 PM
Last post by SteveAus
Today 02:31 AM
1 Replies, 141 Views
Need Help Protecting My Mini
Yesterday 09:26 PM
Last post by Eckstein1
Yesterday 09:26 PM
0 Replies, 145 Views
PAssenger Door won't open from inside using the handle
Aug 9th, 2014 09:13 PM
Last post by couchiedemon
Yesterday 08:52 PM
3 Replies, 504 Views
heat problem
Aug 24th, 2014 10:04 AM
Yesterday 07:43 PM
10 Replies, 692 Views
Heavy Steering
Yesterday 04:44 PM
Last post by fumanchu
Yesterday 07:38 PM
2 Replies, 167 Views
Fan Not Working
Yesterday 07:34 PM
Last post by RikPowell
Yesterday 07:34 PM
0 Replies, 110 Views
Engine overheating problem when idle
Jul 21st, 2014 05:58 PM
Last post by stevemil
Yesterday 07:05 PM
7 Replies, 997 Views
gauges??
Yesterday 04:11 PM
Last post by rob955triumph
Yesterday 04:11 PM
0 Replies, 124 Views
How do I change the roof cable?
Aug 24th, 2014 03:25 PM
by zagatom
Last post by zagatom
Yesterday 02:59 PM
1 Replies, 320 Views
Mini Cooper S with Alta Pulley
Yesterday 01:59 PM
by MAltaSC
Last post by MAltaSC
Yesterday 01:59 PM
0 Replies, 147 Views
speed sensor
Aug 27th, 2014 06:52 PM
Last post by The Nun
Yesterday 12:33 PM
1 Replies, 200 Views
Ľ Wheel & Tire Center
