heated screen - MINI Cooper Forum
post #1 of 3 (permalink) Old Mar 24th, 2014, 07:53 PM Thread Starter
Local Time: 01:10 AM
heated screen
hi only half my heated screen is working any ideas
gazza49 is offline
post #2 of 3 (permalink) Old Mar 24th, 2014, 08:50 PM
Quoted: 53 Post(s)
Each half of the screen heater element is separate, might be a wire displaced that feeds the screen on that side or fuse issue or just a faulty screen, in which case its needs replacing.
The Nun is offline
post #3 of 3 (permalink) Old Mar 24th, 2014, 11:04 PM
Local Time: 12:10 AM
Hi ya
Quick test pull of the trim on the inside windscreen pillar on the side is not working,
Disconnect the two wire red and a brown connect a bulb across the two of them, turn you heated screen on if it lights up your wiring fuses and relay are good,
And your screen is toast
But to be honest if the screen has been changed before, the non original mini ones are not as thick as the genuine ones and you only need a few stone chips to mess up the heating element.
the element is very close to the surface on the non genuine ones :-( my one is trashed both sides needs replacing really
Hope this helps
marque is offline
convertible heated rear window not working Redcooperclubman First Generation MINI Convertible 2 Dec 26th, 2013 02:56 PM
Steering wheel buttons, heated mirrors Sean101 Second Generation MINI Cooper S 4 Dec 16th, 2013 01:38 PM
iPhone on Media Screen cdgill241184 General Discussion 0 Apr 16th, 2013 08:42 AM
Heated Wing Mirros GoldenWonder Second Generation MINI One 5 Jan 7th, 2013 06:22 PM
Problems installing heated seats retro fit wiring loom - Please help !!! aveze First Generation Interior & Ice 1 Nov 26th, 2012 09:28 PM
