2005 Mini S acceleration issues.... - MINI Cooper Forum
post #1 of 3 (permalink) Old Mar 30th, 2014, 01:21 AM Thread Starter
Local Time: 10:45 AM
Greetings one and all. Have a problem with my 2005 Mini Cooper S that I hope some one out there can help with since it seems two dealerships and two other repair places cannot figure out this problem. The cars been sitting for the better part of six months. The car dies out on the freeway or road - the supercharger kicks out and max pedal speed is about 50mph. The current codes are P2122-Throttle Position CKT Low input, P2138 Throttle Position volt correlation.
The car has had a new accel pedal and a new throttle body. I'm thinking that the ECM might be junk in the acceleration circuit but could be wrong.
Ideas? Thanks for any help.
JTLaw is offline
post #2 of 3 (permalink) Old Mar 30th, 2014, 01:14 PM
Local Time: 04:45 PM
Hi ya
i would start buy checking all you vacum pipe work to the map sensor and the orings on the tmap and map sensors
check all the plastic pipe work in your engine bay these do brake or split causing funny faults
check your bypass valve to and make shore the supercharger intake duct it on properly.
you may have a few problems causing it to throw codes that are not relevant to the actual problem.
failing that if you can hook it up to a diagnostic machine you should be able to activate and operate the throttle and check the peddle assy.
it may be a communication error.
have you had the plugs off on the DME i.e. ECU to check for corrosion
the minis do have a problem with chaffing wires around the ABS and fuse box DME area so might be worth taking a good look at the wiring.
i got my bmw diag stuff from ebay cd and lead 30 just a fiddle loading it if you not good with computers i.e. me :-)
hope this help
ps check you SC belt make shore you can see some of the least hole on the tell tail i have seen funny faults with very bad belt slip
marque is offline
post #3 of 3 (permalink) Old Mar 24th, 2015, 12:16 PM
Hi JTLaw & everyone!
I'm just wondering if you ever got this fault / problem fixed?
My friend has a late 2004 facelift model MCS with JCW 210bhp upgrade... And has been experiencing similar problem for over 2 years!
He has spend hundreds, maybe thousands! of pounds trying to get it fixed, at both MINI dealers and independent garages..
Symptoms are as described above.. with common reoccurring Fault code P2138 (and also P1237)
My friend has also had his Pedal, Throttle Body and MAP sensor replaced, but to no avail... sometimes the fault will mysteriously seem to disappear for a couple of weeks after it's been to the garage, but then it returns :-/
ANY ideas / suggestions much appreciated :-)
Thanking you in anticipation.
robdcu is offline
Tags: , ,
PANORAMIC SUN ROOF ISSUES -I'm in talks with Mini Head Office UK PLEASE READ/CONTACT LadyUK General Discussion 63 Oct 8th, 2015 06:56 PM
Mini HQ - Terrible ethics for the customer. jobforacowgirl Dealership Feedback 11 May 22nd, 2014 06:36 AM
Brands Hatch Mini Festival 22/23 June 2013 mab01uk Mini Events 20 Jun 23rd, 2013 11:03 PM
Brooklands Mini Day Sunday, March 24, 2013 mab01uk Mini Events 11 Apr 5th, 2013 07:11 PM
Mini Australia service chilld Dealership Feedback 4 Sep 4th, 2012 06:29 AM
