Rear Parking Sensor Fault - MINI Cooper Forum
post #1 of 7 (permalink) Old Mar 31st, 2014, 01:55 PM Thread Starter
BCM
Local Time: 02:09 PM
Scotland
Got a 55 Cooper S convertible once reverse is engaged the parking sensors either beep constant for about 3 Seconds or nothing at all happens. They don't have a radar beep on them. Where's the best place to start fault finding?
BCM is offline
post #2 of 7 (permalink) Old Mar 31st, 2014, 04:17 PM
Local Time: 01:09 PM
Hi ya
Remove them and clean them first they get full or dirt and water causes problems.
marque is offline
post #3 of 7 (permalink) Old Mar 31st, 2014, 06:39 PM
Quoted: 83 Post(s)
Ignition on on, in reverse and then listen to each sensor and those working will click, the faulty one will not.
You can get them from ebay, a pot of paint touch up and lacquer (thin coats) and then you can fit it.
The rear bumper doesn't have to come off, but all the mountings need to be unbolted so it can be moved far enough.
I fitted mine on my cooper s convertible in 20 mins. 20 all in.
Here's the how to I wrote
http://www.mini2.com/forum/first-gen...placement.html
k3fus is offline
post #4 of 7 (permalink) Old Mar 31st, 2014, 07:23 PM
Had the same problem on my 07 Cooper S Convertible. Had it replaced for about 140 including labour.
Kalenshah is offline
post #5 of 7 (permalink) Old Apr 5th, 2014, 07:08 PM Thread Starter
BCM
Scotland
mini2.com/forum/first-generation-faults-fixes/212721-convertible-rear-sensor-replacement.html
Fantastic mate. Cheers for the link to the how to as well! That's this week's job!
BCM is offline
post #6 of 7 (permalink) Old Apr 9th, 2014, 10:40 PM Thread Starter
BCM
Scotland
Don't suppose you know where to find the paint code for my car, its black, that's about all I know!
BCM is offline
post #7 of 7 (permalink) Old Apr 10th, 2014, 07:57 AM
Quoted: 53 Post(s)
Think on a Gen 1 MINI its under the bonnet on one of the suspension strut towers?
Find the chassis plate, either under the bonnet or in one of the door apertures it will have a code on there.
The Nun is offline
Water under the rear seats and in the boot Emily88 Maintenance & MINI Care 5 Mar 30th, 2014 04:32 PM
MCS Clubman rear parking distance control juge Second Generation Faults & Fixes 1 Dec 14th, 2013 02:12 PM
Rear Parking Sensor Fault adyp1972 Second Generation Faults & Fixes 0 Apr 8th, 2013 09:14 PM
Mini Clubman rear parking sensors andrew007007 MINI Clubman 8 Sep 21st, 2012 03:14 PM
