Noise from front nearside - MINI Cooper Forum
post #1 of 4 (permalink) Old Apr 6th, 2014, 07:09 AM Thread Starter
Local Time: 12:55 PM
My daughter has just picked up a Mini One Seven 2006. I have noticed rather a loud grinding noise coming from the front. It isn't scraping like stones trapped in disc and I have just replaced the pads and discs and it is still there.
It appears to be most evident at low speeds/gears and is marginally worse when cornering, but it also happens in a straight line. It does not go away with mild braking. It is also still there if I drop into neutral and coast.
Any ideas.
MiniArcher is offline
post #2 of 4 (permalink) Old Apr 6th, 2014, 10:46 AM
Quoted: 53 Post(s)
Just picked it up?? Take it straight back, complain and get them to fix it?
The Nun is offline
post #3 of 4 (permalink) Old Apr 11th, 2014, 01:09 PM
Local Time: 10:55 PM
Quoted: 120 Post(s)
Australia Male
Garage
Wheel Bearings? Ball Joints and or Tie Rod Ends OK ? CV Joints OK ? at the very worst, transaxle (Diff). Check the Transaxle (Diff) oil, change the oil and if its full of debris that could be a clue but check the easy items 1st like wheel bearings and ball joints. May also be an Input Gear bearing or a Clutch release bearing if you also have the noise in neutral.
A reputable mechanic with experience with east west engines may help to shed some light on it.
Milpol is offline
post #4 of 4 (permalink) Old Apr 11th, 2014, 03:37 PM
Local Time: 11:55 AM
Most likely nothing more than the dust shield bent in a little and scraping the disc as the wheels rotate.
I think Milpol is scare mongering a little.
Big_Nige is offline
New mini whurring noise from front right wheel mk1990 Maintenance & MINI Care 4 Jan 15th, 2014 07:20 PM
Wits End with this Noise - Please Help! Vicki29 Second Generation Faults & Fixes 12 Dec 29th, 2013 11:35 AM
Front end noise Lexmac First Generation MINI Cooper 3 Dec 28th, 2013 07:42 PM
Front Brake Repair by Dealer - Thoughts on Price? Gregan Wheels, Tyres & Brakes 6 Oct 31st, 2012 09:57 AM
R56 front windscreen wiper noise APJ Second Generation Faults & Fixes 2 Jul 27th, 2012 02:46 PM
