Help Fault Code 0B - Battery positive terminal isolation 1 ; resistance too high. - MINI Cooper Forum
post #1 of 5 (permalink) Old Apr 8th, 2014, 03:21 PM Thread Starter
Local Time: 05:37 PM
United Kingdom View nickw's Classified Ads
Hi, please can someone advise what the best fix for this fault code, this came up on diagnostics for an Airbag warning light fault.
Nick
nickw is offline
post #2 of 5 (permalink) Old Jan 11th, 2015, 05:32 PM
misterh's Avatar
Local Time: 04:37 PM
Quoted: 1 Post(s)
Hi, I have the same problem and same error description, did you get yours fixed? if so can you share the solution with me, I am new on this forum.
cheers
Alan
misterh is offline
post #3 of 5 (permalink) Old Sep 16th, 2015, 08:38 AM
Quoted: 2 Post(s)
Hi,
same code message for me: 0B - Battery positive terminal isolation 1
If I reset it, it comes back every day.
do someone know possible causes?
Thanks!
pilon is offline
post #4 of 5 (permalink) Old Dec 13th, 2016, 02:52 PM
Hi
Got the same problem any one got a fix Mini One
mhorne is offline
post #5 of 5 (permalink) Old Dec 21st, 2016, 01:25 AM
I've had those problems. Does it drain your battery?
Sent from my SM-G900T using Tapatalk
Off-road mini is offline
