HELP!! 04 Cooper S very high fuel consumption on the next day - MINI Cooper Forum
post #1 of 7 (permalink) Old Apr 25th, 2014, 02:33 PM Thread Starter
Local Time: 09:05 AM
Hungary
DIY HELP!! 04 Cooper S very high fuel consumption on the next day
Hi guys,
I have an '04 Cooper S with an Alta performance upgrade. Absolutely in love with the car.
But the car started to eat a lot of gas, almost 20l/km with no sign.
- new spark plugs - factory
- new spark cables
lambda sensors checked - working perfect
air mass flow sensor checked - working fine
Any suggestions? carbon canister valve?
Also the car sometimes only starts on the 2nd ignition. But than it starts immediately. Does not matter if the engine is cold or hot.
Any suggestions on this?
Thanks and all tips, ideas are welcome
kazmermiki is offline
post #2 of 7 (permalink) Old Apr 25th, 2014, 03:47 PM
Hi ya
When you say alta upgrade what do you mean supercharger pulley, airbox, exhaust.
There are a few things it could be
Does the car feel slow or down on power at all
marque is offline
post #3 of 7 (permalink) Old Apr 25th, 2014, 03:56 PM Thread Starter
Hungary
Hi,
what I know it got the supercharger upgarde and the airbox.
The car does not feel slow or down on power at all. It runs as before. Just the gas consumption in in credible. It was never an ECO car but now it is out of control.
What are your tips?
post #4 of 7 (permalink) Old Apr 25th, 2014, 04:09 PM
Hi ya
1) Normally when they start to drink fuel it's the first 02 sensors they still work but there out of range which can cause high consumption. But you say it's been checked
2) If you have a reduced pulley check your tensoer make shore you have 1 hole showing if it's past that, you may have super charger belt slip will cause high fuel consumption.
3) Lazy bypass valve
4) my one gets cranky around 6 to 10 deg c I just reset the DME engine computer
If it has been serviced lately I would have a look at the belt,
do you know what size pulley is
marque is offline
post #5 of 7 (permalink) Old Apr 25th, 2014, 04:15 PM Thread Starter
Hungary
Unfortunately I have no clue about the size of the pulley. I tried to ask the previous owner but he does not know it either.
I will check does things.
How about the weird starting? Any ideas on that?
Thanks a lot
Miki
post #6 of 7 (permalink) Old Apr 25th, 2014, 04:29 PM
Hi ya
Right for your information :-) you must have the correct supercharger belt for the pulley a standard mini belt is no good anyway I can help you there :-) alta only do a 15 or 17% pulleys for your SC, so as long as the crank and alternator pulleys are standard sizes you need a Gates K060535 or 6PK1364 this fits both size pulleys perfect like I said if you can't see the top of the last hole the belt is stretched and needs to be replaced
Starting problem could be a bad O2 sensor which would also point towards bad fuel consumption like I say normally bank 1 which is the first one from the cylinder head.
Also if you are running a standard manifold get the cat checked get a flow check carried out
Have you had your fuel pressure checked you may have a bad filter or a bad pump. The filters never get changed by mini and as a service item,
Hope this is a start :-)
marque is offline
post #7 of 7 (permalink) Old Apr 25th, 2014, 04:35 PM Thread Starter
Hungary
Thanks a lot. Let me check those.
Cheers,
Miki
Tags: ,
Pathetic Fuel Consumption....Do something about it! steeve MINI Countryman 52 Apr 29th, 2015 02:51 AM
high pressure fuel pump leak and head office lies! Shanos General Discussion 0 Nov 29th, 2013 05:24 PM
New Blog Post - Beaulieu Motor Show: National MINI Cooper Day AMAUTOS7 General Discussion 1 Sep 26th, 2013 11:11 PM
08 Clubman S fuel consumption rising over time Blue08ClubmanS MINI Clubman 1 Nov 19th, 2012 05:55 PM
Buying a high mileage cooper s r56 - what to look out for? Minimoos Second Generation MINI Cooper S 1 Sep 14th, 2012 07:44 AM
