Heated windscreen help please....fixed - MINI Cooper Forum
post #1 of 17 (permalink) Old Apr 25th, 2014, 06:56 PM Thread Starter
Local Time: 09:02 AM
After a bit help locating a fault on my heated windscreen, I've checked the fuse all fine, heated screen switch on dash lights up when pressed, changed the relay under the bonnet for the heated screen and have had a new heated screen fitted,
Any suggestions would Appreciated
Dreadlocks is offline
post #2 of 17 (permalink) Old Apr 25th, 2014, 08:34 PM
Hi ya
Your relay for your heated front screen is in you footwell just above the fuse box it's a black one in a holder that the relay is recessed in to.
If you clear the fault memory using the dis then restart the test does it come back ?
Are you trying to test it with the dis ? Or is it a fault ?
Before you get to deep have you check to see if the screen is working properly
Remove the side trims inside disconnect the wires connect a bulb across the terminals and switch the screen heat on if both lights light up, the cars wiring is ok and working
http://www.realoem.com/bmw/showparts...49&hg=61&fg=36
marque is offline
post #3 of 17 (permalink) Old Apr 25th, 2014, 08:48 PM Thread Starter
Thank you for the reply marque, I'm sure the relay I changed was under the bonnet and I'm sure it was the one with the snowflake on
Oh sorry I forgot to put its r52 convertable
post #4 of 17 (permalink) Old Apr 26th, 2014, 12:12 AM
heathwebbo's Avatar
The snowflake symbol is for aircon
heathwebbo is offline
post #5 of 17 (permalink) Old Apr 26th, 2014, 07:44 AM
Local Time: 10:02 AM
Quoted: 53 Post(s)
You need to check the supply to the screen to ensure there is one, and its not unknown for a new heated screen not to work due to being faulty and this occurs more often than not on repro screens not the genuine MINI ones.
If there is a supply there, then check the circuit across the screen with a multi meter or similar.
The screen earth has been fitted properly hasnt it?
And as said, the snowflake is for air conditioning not the heated screen.
Be a bit of a swine if youve had a new screen fitted and you werent pressing the right button to start with?
The Nun is offline
post #6 of 17 (permalink) Old Apr 26th, 2014, 09:14 AM Thread Starter
Thanks for the input guys, I'm going do the checks today, just Iv proberly reading to much and getting a little confused as I have been reading under bonnet fuse FL10 50A K416 Relay heated front screen( this is the one I replaced), and there is one Located behind kick panel drivers footwell K416 Relay heated windshield, just confusing. The windscreen was replaced under insurance but was not working with the original screen, I will have a clearer picture later today,
Right getting a bit closer just need to get inside this kick panel
post #7 of 17 (permalink) Old Apr 26th, 2014, 10:25 AM Thread Starter
The plot thickens got the panel off now I can only see one green relay
post #8 of 17 (permalink) Old Apr 26th, 2014, 11:09 AM
Quoted: 53 Post(s)
Some relays might be on the back of the board too, they are on the Gen 2?
The Nun is offline
post #9 of 17 (permalink) Old Apr 26th, 2014, 03:23 PM Thread Starter
Thank you the nun, looks like you was spot on with the relay location, one ordered so give you a update once it arrives,
It's funny the dealership could not tell me the exact location of the relay,there's cars are quirky
Relay below arrow
post #10 of 17 (permalink) Old Apr 26th, 2014, 04:08 PM
Quoted: 53 Post(s)
Relay below arrow
I used to visit quite a few garages at one time doing outside work and I always found it odd if you asked a mechanic there who was working on them all day long, a question, that seemed fairly obvious to me they didnt know the answer, the only way they could find out was to ask the computer. theres no old school hands on these days, just button pushers.
The Nun is offline
post #11 of 17 (permalink) Old Apr 30th, 2014, 06:42 PM Thread Starter
Yep I'm sure no that, been on the phone to dealers again today after picking up my relay,
I removed the fuse box as I had high that's where the relay might be, nope
So called the dealer ask the parts department to double check the location and they say it's next to the fuse box I say I have the panel of and it's not there, answer was well I don't know that's where it should be, so still no closer but I have a new relay so when I do find it, I would have thought it would have been in accessible place so the search goes on
post #12 of 17 (permalink) Old May 1st, 2014, 06:48 AM
Quoted: 53 Post(s)
Your car should have a heated screen should it, I mean originally? someone previous hasnt just fitted a replacement one and it happened to be heated as thats all that was available?
Thus the car might not be wired up for it?
I dont have the wiring details for the Gen 1 unfortunately only Gen 2
The Nun is offline
post #13 of 17 (permalink) Old May 1st, 2014, 07:12 AM
Quoted: 53 Post(s)
Checked behind the kick panel in the footwell on the other side of the car too?
The Nun is offline
post #14 of 17 (permalink) Old May 1st, 2014, 07:17 AM Thread Starter
Thanks for the reply the nun, yes the cars was orignaly fitted with heated front screen as I have the spec sheet and confirmed with main dealer, I have not look over that side as yet, is that kick panel easy to come off?
post #15 of 17 (permalink) Old May 1st, 2014, 07:25 AM
Quoted: 53 Post(s)
I just suggested it as the GEN2 has relays both sides and the screen one is one the left side thats all.
I would think it comes off the same?
The Nun is offline
Heated windscreen Sean101 Second Generation MINI Cooper 1 Jan 25th, 2014 06:16 PM
heated windscreen Sean101 Second Generation MINI Cooper S 5 Dec 24th, 2013 09:41 AM
Steering wheel buttons, heated mirrors Sean101 Second Generation MINI Cooper S 4 Dec 16th, 2013 01:38 PM
Mini windscreen ident88 General Discussion 1 Jan 29th, 2013 12:05 PM
Windscreen Wipers are driving me INSANE!!!! bax2079 First Generation Faults & Fixes 5 Nov 5th, 2012 04:44 PM
