Front end shake - MINI Cooper Forum
post #1 of 3 (permalink) Old Apr 26th, 2014, 02:15 PM Thread Starter
Local Time: 05:50 PM
England
Front end shake
Hi
I have a 51 plate Mini Cooper. The problem I am having is when the car gets up to 50 mph it's shakes. The front end of the car shakes along with the gear knob. Once I lift off the accelerator the shaking stops. I have read a few threads saying that the engine mount is a common problem, how do tell which engine mount it is if it is an engine mount?
I will post some pics of the car once the weather changes.
R50 cooper with Union Jack roof.
Regards
Chris
Wilko83 is offline
post #2 of 3 (permalink) Old Apr 26th, 2014, 03:05 PM
Local Time: 04:50 PM
Hi ya
I take it you have check the normal things first
1) tire pressures
2) front and rear tire for distortion ( jack it up spin the wheel check for tread delimitation )
3) buckled wheel
4) wheel weights missing
5) wheels bolts are tight
6) abnormal tire wear
Is your car lowered or standard ?
The later minis had a hyd engine mount I think your one may be rubber but with out seeing it it's hard to say. But you can check the rubber bushes and support for signs of damage.
Also get your lower wish bone rubbers checked if one has failed this may be the problem.
If you are un shore about the tires and balance etc, you can swap the wheels form front to back see if the problem moves to the rear.
Hope this helps
marque is offline
post #3 of 3 (permalink) Old Apr 27th, 2014, 04:49 PM
I have this exact same problem, have checked all tracking, had balanceing done. Please let me no if you get to the bottom of the problem
mini1987 is offline
Front end Syrobbo Second Generation MINI Convertible 4 Apr 22nd, 2014 12:11 AM
Front end noise Lexmac First Generation MINI Cooper 3 Dec 28th, 2013 07:42 PM
Mini One Convertible Front Grill varun14 Second Generation MINI Exterior 0 Mar 11th, 2013 05:53 PM
rewinding front caliper piston during front pad change doofus4000 Wheels, Tyres & Brakes 9 Nov 11th, 2012 11:07 PM
About Front wheel suspension NiuNiu First Generation MINI Suspension 3 Aug 21st, 2012 09:45 PM
