Cooper s boils up - MINI Cooper Forum
post #1 of 6 (permalink) Old May 4th, 2014, 07:24 AM Thread Starter
Local Time: 05:43 PM
Cooper s boils up
Hi, im new to this forum. I have a 53 plate cooper s and it runs and drives lovely. How ever when im stuck in traffic it starts to boil up befor the fan kicks in. When the fans running it continues to boil and spits all the water out the expansion bottle. Anyone have any ideas? Does the fan have two stages as when it comes on its going that fast the hole car shakes and it sounds like an aeroplane its that fast.
Thanks in advance
Kristof1989 is offline
post #2 of 6 (permalink) Old May 4th, 2014, 09:12 AM
mab01uk's Avatar
Local Time: 04:43 PM
Quoted: 2 Post(s)
This is a common problem and there are many threads on this if you search on Mini2. The fan has two speeds and it sounds like your first stage fan has failed. Usual cause is a resistor.
More info here:
Solving MINI Cooling Problems.......... - Mini Cooper Register Forum
mab01uk is offline
post #3 of 6 (permalink) Old May 4th, 2014, 06:31 PM
Hi ya
Pretty much as mab says
but I would also say your thermostat could be playing up.
But please remember these minis do run hot first stage cuts in at 105 and second at 112 deg c so using the correct antifreeze/coolant is very very important as it needs a higher boiling point.
Halfords sell it this is what I always use just and it's approved for the mini mix 50/50 and bleed the system properly
Halfords | Comma G48 Antifreeze and Coolant Conc 2L
I would also say if you do not have one all ready but a diagnostic tool or scan gauge so you can check the water temps remember the gauge on the speedo is just a trinket it's only for show
Hope you get it sorted just take your time bleeding it
marque is offline
post #4 of 6 (permalink) Old May 6th, 2014, 09:02 AM Thread Starter
Just had it plugged in, i have 2 fans one on the car, and a spare. I had the computer test stage one of the fan and on both fans only the power steering pump comes on. Is this normal, or should the rad fan come on to at a low speed? Thanks
post #5 of 6 (permalink) Old May 6th, 2014, 12:32 PM
Hi ya
Don't mess with the computer for now.
disconnect the plug on the chassis leg for the fan and do a resistance/continuity check.
You have 3 wires one brown and the other are blue with a red tracer. You will see one or the blue/red wire is thinner than the other that one is your first stage fan resistor, go between the brown and the blue/red wire check for continuity. If you have none the resister is shot common fault easy to fix.
If you stay on the brown wire and go on to the others blue/red you will have continuity. That's the second stage fan.
If the resistor is bad you will need one of these
http://www.ebay.com/itm/For-2003-200...-/360719141283
Hope this helps
Ps I take it you have checked all the fuses and relays but doing this continuity check will tell what direction to go in
marque is offline
post #6 of 6 (permalink) Old May 7th, 2014, 06:49 AM Thread Starter
All sorted now. Put a new fan in it. First stage comes on at 105 and never got hot enough for second stage to kick in and was left running 30-45 mins
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 03:15 PM
Difference in chassis and body R50/53 → R56, Cooper → Cooper S d-b First Generation MINI Cooper 0 Apr 12th, 2014 07:44 PM
True running costs of R56 Cooper S? cupofjavaa General Discussion 8 Nov 23rd, 2013 07:25 AM
Learning to Drive MINIs the Way John Cooper Intended AutoGuide.com MINI News 0 Jul 26th, 2013 06:12 PM
A Look Back at the Three Generations of the Mini Cooper & Cooper S mab01uk MINI in the Media 2 Mar 10th, 2013 10:11 AM
