Manual Trans Problems - MINI Cooper Forum
post #1 of 3 (permalink) Old May 6th, 2014, 10:31 PM Thread Starter
Local Time: 09:55 AM
We have a 2002 Mini Cooper (not an S) with a 5-speed manual trans. We were cruising at freeway speed when we first got a vibration, then harder shaking, then a "bang". I put the clutch in and coasted to the shoulder. Now if the car is in neutral and you slowly let the clutch out it moves forward. If you put it in any gear and try to let the clutch out the car won't move and the engine stalls, like it is in reverse and a forward gear. Also, with the car turned off, and in neutral, I can push the car by hand and move it, although it moves hard. Any advise???
CruznGreen is offline
post #2 of 3 (permalink) Old May 6th, 2014, 10:48 PM
mab01uk's Avatar
Local Time: 01:55 PM
Quoted: 1 Post(s)
Sounds like you have a failed Midlands gearbox or clutch, lots of info here on gearbox:
Early MINI Rover Midland Gearbox - Mini Cooper Register Forum
mab01uk is offline
post #3 of 3 (permalink) Old May 7th, 2014, 12:09 AM
Local Time: 12:55 AM
Quoted: 142 Post(s)
Australia Male
Garage
Thanks for the link mab01uk, I will file that away for future ref but hope I wont need it !
Milpol is offline
Australian MY12 Mini Countryman Cooper S ALL4 Manual - Premature Clutch Life Ratpack MINI Countryman 0 Mar 13th, 2014 03:30 AM
Manually Opening Fuel Filler Flap MiNiGuY First Generation Faults & Fixes 1 Dec 9th, 2013 02:21 PM
Panoramic Sunroofs Issues, Queries, Problems etc LadyUK Second Generation MINI Cooper S 0 Nov 15th, 2013 03:43 PM
Problems with a 2009 Clubman S w/ 106,000 km nickh MINI Clubman 1 Oct 10th, 2013 11:55 AM
Annoying electrical problems HELP!!!! luckerww Maintenance & MINI Care 3 Oct 21st, 2012 09:56 PM
