Noise When Turning Off Engine - MINI Cooper Forum
post #1 of 11 (permalink) Old May 7th, 2014, 08:50 AM Thread Starter
Local Time: 11:02 AM
Japan
Hi Guys,
When I turn off my engine (Mini Cooper S-2003) I can hear a 'winding down noise' the best possible way to describe it is like the noise a vacuum cleaner makes when turned off...
Anything to be worried about or is it just the SC winding down?
Thanks for any information!
Dave
DaveKay is offline
post #2 of 11 (permalink) Old May 7th, 2014, 05:13 PM
heathwebbo's Avatar
Its nothing to worry about its normal they all do it, the supercharger stops as soon as the engine does as its run by the auxiliary belt, I think its the steering pump that makes the noise after switch off
heathwebbo is offline
post #3 of 11 (permalink) Old May 8th, 2014, 10:14 PM Thread Starter
Japan
Nice one thanks!!
DaveKay is offline
post #4 of 11 (permalink) Old May 9th, 2014, 03:03 AM
United States Male
also when you pass 108'C the cooling fans will kick on after the car has been turned off. If your mini shudders when you shut it down that could be an issue.
TheGypseDanger is offline
post #5 of 11 (permalink) Old May 9th, 2014, 05:52 AM Thread Starter
Japan
Thanks mate...car has never shuddered when turning off even the fans are on! cheers
DaveKay is offline
post #6 of 11 (permalink) Old May 12th, 2014, 03:57 PM
United States Male
I did look into this a little bit. Mine makes the same sound so I had my fiance` start and shut off my car while I was under it. When you put the key into position 2-3 the fuel pump starts up and the fan for power steering starts up, air pressure builds for start once started the power steering pump kicks on, and if your using air or heat your blower motor starts. when shutting down they go in the same order, fuel, power steering, super charger. Creates like a winding down effect. I read/ heard it is completely normal.
post #7 of 11 (permalink) Old May 14th, 2014, 02:33 AM Thread Starter
Japan
Thanks for further information! Sounds like its all normal! Its all new noises that i'm trying to get used to! Thanks a lot mate, really helped!
DaveKay is offline
post #8 of 11 (permalink) Old May 14th, 2014, 03:45 AM
United States Male
No problem glad to be a mini brotha
post #9 of 11 (permalink) Old May 14th, 2014, 07:25 PM
Quoted: 40 Post(s)
They all do that, mate.
Those long sleeves will ride up with wear, sir.
The cheque's in the post.
Angib is offline
post #10 of 11 (permalink) Old May 14th, 2014, 09:08 PM
Local Time: 04:02 AM
Mexico
Is it normal that the ps pump turns on while the car has been off for about 15-20min?
Its a 2003 mini s, just did the ps pump change because the other kept on running when switched off.
Emmanuel is offline
post #11 of 11 (permalink) Old May 14th, 2014, 09:57 PM
Mexico
I think it's not normal... It just drained my battery!
Emmanuel is offline
Ran my Mini out of oil and now I have engine noise. Timbo66 First Generation Faults & Fixes 12 Apr 17th, 2015 09:48 PM
2005 Cooper S Squealing Noise Independent of Engine Speed uilleann-piper First Generation MINI Cooper S 1 Sep 24th, 2013 09:18 PM
MC 2003 hatch, engine noise / high revs on start up Dylangilbey General Discussion 0 Feb 7th, 2013 08:22 AM
NEED HELP 2008 Mini R56 BAD Engine noise 160k kentuckynet Second Generation MINI Cooper 4 Feb 4th, 2013 11:22 PM
Weird noise when starting car and turning to left :/ Mehreen First Generation Faults & Fixes 0 Nov 18th, 2012 04:45 PM
