P0301 Fault - MINI Cooper Forum
post #1 of 3 (permalink) Old May 9th, 2014, 07:19 PM Thread Starter
richas's Avatar
Local Time: 10:37 AM
P0301 Fault
Hi,
I have a 2005 R50 Cooper. A while back I replaced the O2 sensor after I got an error code, can't remember the number but it was "post cat mixture rich" or something. That fixed that problem.
Months later I get a P0301 Cylinder #1 misfire fault. The engine started running rough like it was on three cylinders.
I find a corroded terminal on the coil and so I replace the coil (MSD), wires, and plugs. Seemed okay for a while.
Then it came back. So I moved the #1 injector to #3. This did not help.
I put the old spark plugs back in, no joy.
I have gotten the fault and reset it MANY times.
The typical symptoms are:
The engine may be idling a bit rough, like a partial misfire.
It never occurs when I am on the gas or the highway and I commute 40 minutes each way everyday.
I will take my foot off the gas and the engine will stumble, the light will come on (blinking first), and the car will be running rough like it is running on three cylinders.
Here is an interesting bit, if I turn the car off and restart the problem goes away. Though the idle always seems a bit rougher than it should be.
Not sure what else to do besides try an ECM. ($$$$)
Rich
richas is offline
post #2 of 3 (permalink) Old May 10th, 2014, 12:04 PM
Local Time: 05:37 PM
Hi ya
Get your fuel pressure and flow checked
Also Get a leak down check carried out I think you may have burnt a valve out :-(
marque is offline
post #3 of 3 (permalink) Old May 13th, 2014, 05:23 PM Thread Starter
richas's Avatar
Originally Posted by marque View Post
Hi ya
Ordered a Fuel pressure gauge. The next time this happens I will pull over and measure........
Rich
richas is offline
Restraint System Fault Richard of the Hills Second Generation Works 0 Oct 10th, 2013 11:39 AM
Ubiquitous airbag fault - tracing actual problem tieak First Generation MINI One 2 Apr 24th, 2013 10:57 AM
Ubiquitous airbag light - tracing the actual fault tieak First Generation Faults & Fixes 5 Apr 23rd, 2013 12:05 PM
Rear Parking Sensor Fault adyp1972 Second Generation Faults & Fixes 0 Apr 8th, 2013 09:14 PM
R56 Cooper S fault codes/ no boost das882 Welcome New Members 3 Mar 27th, 2013 09:45 AM
